Dose any one know what cause’s the bottom cord of trusses and wall studs to transpose through to the interior side of the drywall. It’s almost like it’s shadowed.
There's a constant source of clean water for you to use, and all you have to do is collect it.
IIRC, it is caused by condensation. Even though your fiberglass insulation might have an R value of 13, the studs are only about R1 per inch, so about R3.5. Thermal bridging...So the places where the studs are get colder and moist inside air condenses on it drawing dirt and such.
The shadowing should just be dirt and can be cleaned off.
"A free society is a place where it's safe to be unpopular."
-- Adlai Stevenson
Do you burn candles?
The house is an electrican buddy of mine so I'm sure he uses good old kilowatts for his mood ligthing:-]
