In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Thermally broken studs – followup
Gene_Davis | Posted in General Discussion on August 27, 2009 07:35am
Thought I would post a couple pics, now that the place is mostly framed out.
Studs and plates are all 2x4s, to which the manufacturer has laminated a 1.5×1.5 layer of rigid iso foam, then an inner nailing surface of 1/2″ OSB.  Maker is Nordic Engineered Wood Products, of someplace in northern Quebec.
Insulation in walls will be 3″ nominal thickness spray iso foam, the fillets of which will pretty much ensure no delamination occurs between the rigid foam thermal break and the studs.  Or so the owner hopes.
My apologies to the dialup folks.
I helped frame for a couple days, and in my experience, the loss from delams was pretty minimal.  The way that Nordic makes these, the lams are resawn once the glueup is done, with the inside parts measuring about 1-3/8″, so that any ganged members are tight, wood to wood.
“A stripe is just as real as a dadgummed flower.”
Gene Davis        1920-1985
  1. PatchogPhil | Aug 27, 2009 09:52pm | #1
    I am curious about the price per 2x4.
    Also, what was the reaction of the building inspector(s)?
    In your opinion, could this concept be duplicated with sheets of foam and OSB, cut into strips and glued onto "regular" studs?
      Gene_Davis | Aug 27, 2009 10:13pm | #2
      Can't help w/ price.  Didn't ask.  Whaddya payin' for a 2x6x8?
      What building inspector?  We are in one of those many, many parts of the country where inspection does not exist.  Permits, yes.  Permit fees, yes.  Inspection, no.  C.O. at the end, for another fee, if you need one.  Otherwise, site visits are not done by Mr One-And-Only-Inspector.
      Yes, you could make these, but who would bother?  The labor would be a killer.
      Mike Smith, well known here at Breaktime for his photo essays, from foundation to finish, would prefer to put the stop to thermal transmittance by building a "Mooney wall" system, essentially a 2x4 frameup with 2x2 horizontal strapping at 16" o.c. inside.
      This is just another way to skin the cat.
      "A stripe is just as real as a dadgummed flower."
      1. PatchogPhil | Aug 27, 2009 10:31pm | #3
        It's a cool idea. (Or is it "temperature neutral"?)As far as labor being a killer, if it were a DIY project then often the labor is moot. Dollar savings is more a driving force.I was curious if an inspector would care that the drywall would not be screwed to a stud.Those studs remind me of an abbreviated version of a foam & osb sandwich structural wall system.
          Gene_Davis | Aug 27, 2009 10:56pm | #4
          If such a comment were to ever come from Mr Know-It-All, I would send him up the road and insist that he fail all the places hereabouts built with SIPs and ICFs, then when he's done doing that successfully, come back and talk to me.
          1. frammer52 | Aug 28, 2009 01:34am | #5
            HHHEEEEEEE!  I guess you told him!
          2. Henley | Aug 28, 2009 02:55am | #6
            Side note- I used to stay at a lodge up in Keene. Adirondack mtn. lodge maybe. Dirt cheep and much like a youth hostel . Do you know if it's still around?
        2. ponytl | Aug 28, 2009 05:07am | #8
          just curious... why not frame with standard 2x stock... sheath 100% with foamboard... then add nailing strips/fir it out... same thermal break
          p
            Gene_Davis | Aug 28, 2009 05:13am | #9
            Here's what somebody asked after you did just that.
            "Why didn't he just use those thermally broken studs you can get from Quebec?"
          2. PatchogPhil | Aug 28, 2009 10:16am | #12
            Then it's harder to spray in the foam to seal the outside sheathing to the studs and the interior foam to the interior nailing strip.
            Guess it depends on what your insulation will be???
  2. RedfordHenry | Aug 28, 2009 04:38am | #7
    Interesting product.  The blue foam looks like extruded polystyrene, are you certain that it's iso?
    Also wondering what do you mean when you say "the loss from delams was minimal"?
    Thanks for posting.
      Gene_Davis | Aug 28, 2009 05:18am | #10
      Iso is just my quickspeak for polyisocyanurate.  Dowboard is iso.  Thermax is foil-covered iso.
      Read about it at wiki: http://en.wikipedia.org/wiki/Polyisocyanurate
      1. dovetail97128 | Aug 28, 2009 05:45am | #11
        Just a clarification.
        Not all "Dowboard " is. Unless Dow is now marketing their ISO under the name "DowBoard" http://building.dow.com/na/en/products/insulation/rigidfoam.htm#Polyisocyanurate
      2. egdc | Aug 28, 2009 05:44pm | #13
        I have to say it doesn't look like polyiso to me, i've never seen it blue all the way through, just on a surfacelooks like xps, dow xps is blue throughout.
DeWalt Recalls 12-in. Sliding Compound Miter Saws
Purchasers of certain models should stop using the saw immediately and contact DeWalt to receive a free repair kit.
  • Podcast 486: PRO TALK With Builder and Remodeler Mason Lord of HVP in Kent, CT
  • Get Stunning Views With Folding Glass Doors
  • Keep Craft Alive Podcast: Episode 20, Ian Schwandt, TDS Custom Construction
  • Step-by-Step Install Prehung Exterior Doors
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Outdoor Projects
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
