Tile over Stadler radiant heat panels
| Posted in General Discussion on July 15, 2000 07:23am
The panels are staggered and screwed to 3/4″ t&g subfloor (6 screws per panel), which was glued and nailed to the joists. Stadler claims it’s ok to tile over the panels, as long as we use high quality latex thin set and grout. Of the two best local tile shops, one agrees with Stadler and one says I need to install 1/4″ or 1/2″ cement board under the tile.
Obviously, I’d like to not add another layer unless I really have to.
  1. Jeff_Katz | Jul 15, 2000 07:23am | #1
    The panels are staggered and screwed to 3/4" t&g subfloor (6 screws per panel), which was glued and nailed to the joists. Stadler claims it's ok to tile over the panels, as long as we use high quality latex thin set and grout. Of the two best local tile shops, one agrees with Stadler and one says I need to install 1/4" or 1/2" cement board under the tile.
    Obviously, I'd like to not add another layer unless I really have to.
  • FHB Podcast Segment: Patching Drywall Near a Shower
  • The Unabashed Maximalist
