FHB Logo Facebook LinkedIn Email Pinterest Twitter Instagram Tiktok YouTube Plus Icon Close Icon Navigation Search Icon Navigation Search Icon Arrow Down Icon Video Guide Icon Article Guide Icon Modal Close Icon Guide Search Icon Skip to content
Tile Roof Underlayment Choice
daen | Posted in Construction Techniques on September 17, 2008 04:07am
I am not a builder by trade, but building my own house and shop. These are located in the phoenix metro area.
I am getting ready to set trusses and sheath the roof on the shop. We will be using a tile roof. I am looking for feedback on people’s choice of underlayment. The roof does not have any valleys, but it does have a couple of sections where the roof plane abuts a knee wall on a taller section of the building.
I am building this for myself and have every intention of being here for a long time. If the underlayment fails in 20 years I’ll be the guy fixing it most likely. And like most of us here, I want the absolute best possible product – without breaking the bank…
I have spent a little time reading on this subject here at Breaktime. The choices seems to boil down to two: 30 lb felt or Ice & Water. The downside of Ice & Water besides the cost is the rated lifespan of the product. The downside of felt is that it does not self seal around nail holes, etc.
Since this is in the desert, we don’t have an ice dam issue. We do have long HOT periods to dry stuff out. We also can get a couple of inches of rain in an hour with driving wind – occasionally.
I have read where the felt should be doubled. I saw one description that the doubling is achieved by starting with a 19″ half strip at the eaves and then overlaping each run by that much. That versus running one full covering of felt and then start over again at the eaves and running the second.
Any advantages, theories on combining the two products. Since I don’t have any valleys, would there be any benefit of using the I&W at the roof/wall intersection? The building is being made from Rastra (ICF material) and the flashing at this intersection will be kerfed into the Rastra block. So any I&W run up the sidewall will be no taller than the flashing.
I have not priced either approach yet. Can someone give me a rough price comparison for any sized roof for felt vs. I&W?
Thanks for the great feedback.
-dch
  1. frammer52 | Sep 17, 2008 04:44pm | #1
    I suggest you follow the instructions from the manufactor.  I know I almost signed up as a preferred installer back in the 80's and they had rules to follow.
  2. seeyou | Sep 17, 2008 05:25pm | #2
    What brand/type of tile? Some manufacturers have a proprietary underlayment which is typically a re-branded I&WS.
    Here's what we typically use:
    http://www.interwrap.com/titanium/udl_30_main.html
    Not sure how it would last in your climate, but I've not had any problems with it.
    doubling is achieved by starting with a 19" half strip at the eaves and then overlaping each run by that much. That versus running one full covering of felt and then start over again at the eaves and running the second.
    The advantage to double lapping vs double layers is that if any water penetrates the 1st layer, it theorectically gets brought back to the surface of the underlayment. If water penetrates the top layer of a double layer, it remains between the two layers until it finds a hole in the 2nd layer.
    I'm unsure of how that affects I&WS. The main enemy to I&WS is UV rays, so if the "open" time is limited, then that might be your best choice.
    The old tile roofs around here used a hot mop underneath.
    You didn't specify the slope of the roof. That would also influence my decision.
    Won't hurt, might help. I've heard of Rastra, but have never touched it. Don't know about it's water turning abilities. If it absorbs much, then you're probably in trouble if you haven't thru-flashed when the wall was laid.
    1. MikeSmith | Sep 17, 2008 07:37pm | #3
      like seeyou, we're using all 2d generation roof underlayments... including the titanium
      we use felt under our siding, but haven't used felt on roofs for almost 10 yearsMike Hussein Smith Rhode Island : Design / Build / Repair / Restore
    2. daen | Sep 17, 2008 07:45pm | #4
      Roof pitch is 12:4.
      Rastra is not waterproof. The Rastra is not on the knee wall yet - Rastra makes a flat panel that does not get grouted. I am using this for the gable ends and the knee walls. The Rastra gets covered in Stucco.
      Your recomendation on the flashing is to run it up the framed knee wall and then put the Rastra over it. That would work, but would be impossible to remove later. My thoughts on "kerfing" the flashing into the Rastra would mimic flashing mortered into a brick chimney.
      I have attached a sketch of a cross section of what I have in mind.
      Thanks for the input.
      1. daen | Sep 17, 2008 07:56pm | #5
        Looks like the attachment didn't come through.... Here it is
  3. PenobscotMan | Sep 18, 2008 01:27am | #6
    In Maine, I just installed some IWS. The box says NOT recommended for the Desert Southwest. That would be you.
  4. seeyou | Sep 18, 2008 03:17pm | #7
    http://www.tamko.com/ProductDisplayPage/tabid/53/ControlType/productDisplay/itemid/1575/Default.aspx
  5. Piffin | Sep 18, 2008 04:27pm | #8
    traditional is a dual ply of 30# installed by lapping 18"
    For a step up, use Rooftopgaurd II which is toughr and has limited selfsealing at nails. It goes on fast too, being 5' wide, and will handle turning up that 18" at kneewalls well. A good compromise between the 30# and the bituthene
  6. Nashsquirrel | Sep 19, 2008 07:55pm | #9
    Just a Thought, I used a product like this under 56sq snap lock standing seam, easy to work with and was impressed with how water tight the project was during instalation of the roof.
    http://www.energy-innovation.com/files/file/StrongSeal%20Roofing/StrongSeal%20SA%20Technical%20Data_12_07.pdf
Managing HVAC Load Calculations
It is imperative for someone at the end of an HVAC installation to commission the job to ensure the efficiency of the system.
  • Issue #320 – Dec. 2023/Jan. 2024
  • Podcast 607: Wood Foundations for Winter Builds, Adding Headroom, and Aeroseal for Leaky Ducts
  • Podcast 607: Members-only Aftershow—Holiday Gifts for Home-Building Enthusiasts
  • Fine Homebuilding Issue #320 Online Highlights
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Fine Homebuilding Archive
    Buy Now
  • Pretty Good House
    Buy Now
  • Code Check Complete 3rd Edition
    Buy Now
  • 2024 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 320 - Dec 2023/Jan 2024
    • How to Reuse Salvaged Wood
    • Chainsaw Retrofit and Energy Performance
    • Maximize HVAC Efficiency
  • Issue 319 - November 2023
    • Nearly Net-Zero ADU
    • An Easy Approach to Coffered Ceilings
    • Understanding Types of Roof Vents
  • Issue 318 - October 2023
    • Make Mudsills Square and Level
    • Turn Up the Heat With Induction Cooktops
    • The Fine Homebuilding Interview: Lloyd Alter
  • Issue 317 - Aug/Sept 2023
    • Finishing Drywall With Seamless Results
    • A Flat Roof in a Cold Climate
    • Compact Cordless Shop Vacs
  • Issue 316 - July 2023
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
