toliet rough in question
| Posted in General Discussion on June 15, 2001 06:42am
I am adding a bathroom and would like to know the standard distance from the wall framing to toliet drain for the plumbing rough in.
Thanks for your expertise!
  1. nigel_martin | Jun 15, 2001 03:44am | #1
    12" from the wall finished surface. Make sure you leave enough elbow room each side. Take care with the placing of the feed pipe.
    1. Mike_Smith | Jun 15, 2001 04:14am | #2
      *12 is standard... 10 & 14 usually available.. you can rough it further away if you want.. but the space between the tank and the wall will increase....nigel's elbow room is important.. 36 is recommended.. 30 absolutely minimum.... try to keep it at 36....
      1. Wet_Head_Warrior | Jun 15, 2001 05:44am | #3
        *Good responses...if you are operating under the UPC it must be a 15" minimum from center to side wall. if you go over 18" you start having trouble reaching the TP so if you have a space wider than 36" consider sliding it to one side.The 12" from finished wall to center of closet flange is correct also. Watch out for the floor joists. There are offset flanges available if you need a couple of extra inches. But they tend to clog up more I've noticed. Also if you buy a 10" or 14" rough in toilet...OUCH! They isn't cheap pal.
        1. Scooter_ | Jun 15, 2001 06:42am | #4
          *12" from the finished wall (not baseboard) Buy the toilet first. Measure from center to be sure. I usually find it is 12 and 1/4 or 1/2.14" roughins are fairly old fashioned, and haven't seen them in construction (except for historical homes) in years.
  2. greg_s | Jun 15, 2001 06:42am | #5
Rescuing Old Hardware
Whether it’s already in your house or picked up at a flea market, vintage hardware almost always needs help.
