Trying Out an Emmert Vise Clone
BobSmalser | Posted in Tools for Home Building on May 2, 2005 05:42am
Was hired for a job at the end of the month that requires a freestanding bench, something I’m not using in my temporary shop, so I drug my father’s old bench out of storage to fix up for the job. As part of the fixup I sprung for one of those 200-dollar Emmert U-Series Patternmaker Vise clones made in Taiwan. Always wanted an old Emmert or Oliver, but finding a complete one at a reasonable price has been a bit of a challenge….I’ve had good luck with Taiwanese castings before, so why not? 200 bucks is less than half the going rate for a complete Emmert, and if Highland Hardware with ship 60 pounds 3000 miles to me for 12 bucks, now is the time.
I was just a little shaver, but one of my first memories is “helping†him make that bench. He’d just quit his job at a large urban shipyard to move his young family back to the country, and was building a new shop from scratch like I am today. He didn’t have any power tools yet, and that entire bench was made using hand tools…an old-growth, 20 rings/inch Longleaf Pine frame with an American Beech top laid up using rough-cut 2X2’s through-bolted with threaded rod and steel drifts. In fact, the frame joints are also bolted together using old black iron square-head bolts and drifts….except for the lack of galvanizing just like he bolted up minesweeper frames for the Navy.
http://mprime.com/Emmert/how_to.htm#How%20to%20Install
Carl Mathews has an excellent site on these patternmaker vises, to include mounting instructions that provide the most desirable installation with the rear jaw face flush with the bench. The instructions and template that come with the clone mount the vise with the rear jaw in front of the bench, which takes up 4 or so more inches of space than necessary, and isn’t as well balanced.
Unfortunately, that’s the way I had to mount the clone, because of the location of Dad’s bolts through the unglued beech top. After 50 years of hard use, that top was worn hollow and out of square, and as it had too much sentimental value to replace, I merely made an overlay of mixed-species strips 1 1/2†thick and bedded it onto the old top.
The easiest way to mount one of these vises is to make a bench especially for it. Placing the vise between two legs rather than hanging off the end would be wise, and if the top is made exactly 1 5/8†thick, minimal mortising is required for installation. Typical for me, I did it the hard way in a bench top now 3 ½â€ thick….and as Dad only flattened to top of that bench back in 1954, the big plunge router got to take the day off in favor of the big chisels.
As is my wont, all the critical bearing surfaces that will take a pounding were bedded in thickened epoxy…10,000 gunsmiths can’t be wrong…the Record clone end vise I also installed is shown in the pic above.
I like quick-action vises, something that’d be impossible to do on an Emmert, and not common in end vises. I used my old Jet in an end vise installation that features a sliding board in addition to the vise dog that can be locked into position to hold a large panel against the bench dogs. The travel on the vise is 7 ½â€, and the dog holes in the bench were drilled to match. The sliding board of hard, heavy Brazilian Cherry stair tread was drifted with bronze rod for reinforcement.
Range of motion isn’t a problem with the Emmert, which has over 13†of usable travel…
…allows the jaws to be skewed 5 degrees either way to hold mild tapers…
…comes with an auxiliary jaw that’ll hold up to a 20-degree taper…
…and is just as stable holding work pieces at 90 degrees at any degree of rotation as it is holding them level.
The vise is surprisingly simple, using cam locks to hold any degree of elevation and rotation desired. The rotating collar cam lock on the right allows 360-degrees of rotation and the tilt arm cam lock on the left allows over 90 degrees of elevation. One fault of the clone is the direction to mount that cast iron tilt arm base to the bench with the #10, ¾â€ cheapo screws provided. They have to be pulling my leg. View Image As that tilt arm must absorb some pounding, I used White Oak blocking and #10 machine screws 2†long, in addition to bedding and gluing the base using marine epoxy. Machine screws run into a properly sized hole are much stronger in every respect than common wood screws, and a tad of propane torch will easily release my bulletproof installation when the time comes.
The handle supplied also has to feed the stove as soon as I get around to turning a properly sized one….but other than those picayunes, the castings and machining are excellent…the vise required no calibration of its adjustment features and when mounting the leather jaw pads I got perfectly-even squeeze out of the contact cement, which means the jaws are as flat as they need to be.
“When we build, let us think that we build forever. Let it not be for present delight nor for present use alone. Let it be such work as our descendants will thank us for; and let us think…that a time is to come when those (heirlooms) will be held sacred because our hands have touched them, and that men will say, as they look upon the labor and wrought substance of them, ‘See! This our father did for us.’ “ –John Ruskin.
    rjw | May 02, 2005 06:04am | #1
    Great set of pics and story.
    Thanks!
    Sojourners: Christians for Justice and Peace
  2. BillBrennen | May 06, 2005 08:00am | #2
    Thanks for the great post, Bob! I am impressed that $200 buys you the parts you cannot easily make yourself. If the iron is good, you got yourself a fine vise for a low price. Update the board after you have used it somewhat, especially if there are surprises.
    Bill
  3. DougU | May 07, 2005 02:00am | #3
    Bob
    I always enjoy your slide shows.
    Very informative.
  4. daveinnh | May 15, 2005 02:17am | #4
    Thanks for the demo - very informative.
  5. FastEddie1 | May 15, 2005 04:56am | #5
    Another great story.
    What's wrong with the handle?  Why do you need to turn a new one?
    You mentioned that you got even squeeze out of the contact cement.  I thought contactr cement was allowed to set before joining, so what was there to squeeze out?
      BobSmalser | May 15, 2005 06:28am | #6
      The handle likely was from stock made up for another vise.....way too loose for my tastes.
      A fairly thick layer of contact cement is required to fill the milling marks in the vise faces....enough for some squeezeout even tho it was left to set up for 30 minutes.  I used two coats on both iron and leather.
      Been using the vise all day every day since and I really like it.  Others have described the need to build in stops for the vise to return to level after rotation....but I'm happy without any of that.
       â€œWhen we build, let us think that we build forever. Let it not be for present delight nor for present use alone. Let it be such work as our descendants will thank us for; and let us think...that a time is to come when those (heirlooms) will be held sacred because our hands have touched them, and that men will say, as they look upon the labor and wrought substance of them, ‘See! This our father did for us.’ “ --John Ruskin.
Mortar for Old Masonry
  • xoxo test post 3
  • xoxo test post 2
  • xoxo test post 1
