In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
unbroken path of support
Lunicy | Posted in Construction Techniques on May 3, 2003 04:56am
I need opinions. I have a new beam in a 3 story Victorian holding the 2nd story joists. It needs a post or column. Should I have the steel guy make a 16′ lally to go from the beam, through the 1st story, into the basement, onto a footing. OR Can I use a 4×4 (8′ long)to the 1st floor, install new dbl. joist under post, install regular 8′ lally column under that. What seems right. Project has to be done soon and will be inspected. The steel guy will take a while to make a column, so I’m pretty much asking if the other way is OK, to code, safe, etc…
Thank you
Can’t I go 1 day without spilling my coffee?
  1. Piffin | May 03, 2003 05:06pm | #1
    If it is getting inspected by a codes enforcement officer, he is the one to pose this Q to. he may require some enginewering.
    But the typical manner for this is the second option you present, with the exception that I would fill the joist space below with grain running vertically. aligining the grain horizontally invites shrinkage/settling problems.
  2. alias | May 03, 2003 05:13pm | #2
    hey lu- continuity is the key for superior structual integrity. you can have a flange's welded to the column to pick up all bearing points. this the way i would do it . granted depending on your loads the size of the columns will varie, cement filled, square,round. the longer the larger the column must be. point loads on large victorians can be all over the place because of roof loads , high pitch's, reverse's, and open floor plans. etc. and if the joists have been cut up for plumbing up-grades all these components add up to the larger/longer lally.I.M.H.O. i tend to over build -it's just my way- over kill has been used around me. but i never loose sleep either... cheers bear
Tools for Managing Home-Building Financials
Production manager Ian Schwandt explains how financial tools such as QuickBooks or Buildertrend can help companies track project costs for a healthy outcome.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Podcast 487: Cedar Closets, Conditioning a Woodshop, and Regional Construction Jargon
  • Podcast 487: Members-only Aftershow
  • Festool's Domino: Worth the Dough?
  • Podcast 486: PRO TALK With Builder and Remodeler Mason Lord of HVP in Kent, CT
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Pretty Good House
    Buy Now
  • Outdoor Projects
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
