I have always been told/read that an unheated crawl space should be vented due to possible dryrot. However I live in the foothills of N Ca. where it is cold and relatively dry in the winter and warm and dry in the summer. I would like to seal those vents. I have all my copper main runs (insulated) for radiant floor suspended under the house as well as domestic water lines and even though they are insulated everything would stay alot warmer.Does anyone think this is a mistake?
A decorative transom fills in the space between a stock door and the home's 9-ft. ceiling, saving the cost of a custom door.
How about mechanical vents that you can open and close?
Chuck S
Have a look at the basement insulation articles over at buildingscience.com
Based on what I read there, I would not ventilate a crawlspace. Instead, I would seal it with 6 mil PE (taped and foamed), followed by a generous 2+" of XPS to insulate it. That way your radiant system does not attempt to heat the ground around the house, nor can humidity enter the space. Problem solved.
