Listen to gabe. He speaks truth.
My brother in-law and I are building a small poolside building (varanda?)
Inside will be a dry sauna, toilet, storage, etc. I was thinking about using v-groove cedar siding inside instead of drywall and was wondering if I should use a vapor barrier behind it and also if it should be back-primed first. Thank you in advance for your words of wisdom! Al
*Alan, what's the rest of the wall composition going to be? Outside finish, stud walls, masonry, stucco, insulated, heated, A/C, location?Gabe
*Gabe, WE got 2x4, insulated w/batts and vinyl siding. No AC, Thanks Al
*Alan,You might want to rethink the A/C; it can get pretty warm in them saunas Bob
*Hi Al,Yes to the VB and no to the back priming.Gabe
*Listen to gabe. He speaks truth.
*Thanks Gabe!
*My husband and I are looking at sauna kits vs. building one from scratch, and the vapor barrier commonly used in the kits is a kind of aluminum foil. The reasoning behind that is ( we asked) that plastic deterorates over time with that kind of heat, and that the aluminum foil reflects back into the sauna, etc. The same stuff is available from the people who make that bubble-wrap type insulation (one brand is called Reflectix). You might want to consider that.
