how deep and is it really sand all the way???
WOW!!! What a Ride!
Don't know.
Could hit some clay since I'm about twohundred yards from LakeErie.
Don't expect and shale.
how big a tube you looking to put in?????
Don't know. Just remembered brownbagg mentioning it in a different thread the other day and I got to thinkin'.
Ever get to thinkin'?
bb-how big of a compressor would one need powering a 1 inch hose and would that work?
get the largest pump you can get and drop the pickup in the lake....
hook on and go for it...
but the ford has been running ok of late.
now that ya mentioned it...
not fer long...
He meant the Dodge, not the ford
dropping the ford in the lake is too good for it...
Thanks all.
Summer is coming.
odds are it will be spread out over the 26th and 27th of July for a total of 31 hours
LOL
What is it, the waterhose slides inside the pipe meeting the soil and the water/sand continues to flush out the top?
water goes down the tube abd moves the soil out of the way and lubes the pipe in at the same time...
excess water and soil comes back up around the outside of the pipe...
just hook a firehose to a pvc pipe and keep pushing down, you going get wet, but you can do about eighty feet in ten minutes.
Is PVC suitable for well casing?
PVC well casing is suitable.
I stuck 30' of it in the mountain here (until I got down to hard rock). Not many use steel casing here anymore.PAHS Designer/Builder- Bury it!
You could have a lot of boulders, but maybe not.
http://www.purdue.edu/dp/envirosoft/private/src/drill.htm
http://www.lehmans.com/jump.jsp?itemID=882&itemType=CATEGORY&iMainCat=878&iSubCat=882&show48=1
My uncle had a well on the atlantic shore in NC. Water jetted and PVC. Did it himself and had no problems at all.
Edited 12/22/2007 7:51 am ET by MarkH
never used a waterjet in sand.... just a sledge hammer...18' in about an hour or so
, wer ist jetzt der Idiot ?
450 gpm, 3" pump on 4 cyl engine of '84 chrysler at 3000 rpm,
20 gal of clorox into the pond, brought up a few yards of sand from 60 ft. in about 4 hours, rock and boulders above that though, probably easy if you are pure sand.
zat you?
