what ducting should I use
andyfew322 | Posted in General Discussion on October 28, 2008 05:32am
So I really want to put in some type of dust collection ducting for my WS that will hook up to my 14 gal shopvac (2 1/2″ port). What is the best ducting material to use, I want to keep to a fairly small budget. PVC I hear creates static elec. but I could always wind copper wire around it. if I wrap wire around it can I connect the wire to any of the copper water pipes running around my shop ceiling?
I’m just sayin’
    IMERC | Oct 28, 2008 05:37am | #1
    use snaplock pipe...
    WOW!!! What a Ride!
    1. andyfew322 | Oct 28, 2008 05:39am | #2
      ok, now what is snaplock pipe?
      I'm just sayin'
        IMERC | Oct 28, 2008 05:42am | #3
        single wall metal pipe used for venting...
        http://www.precisioninstallationproducts.net/p-3781-10-x-60-snaplock-vent-pipe-30-guage.aspx
        here 30ga is way to light and flimsy...
    Dinosaur | Oct 28, 2008 07:05am | #4
    4" Fittings for
    Dust Collection
    Systems
    2-1/2" Fittings for Shop Vacuums
    2-1/2" Fittings
    for Shop Vacuums
    Veritas¯ Magnetic Dust Chute
    Veritas¯
    Magnetic
    Dust Chute
    Veritas¯ Cyclone Lids
    Veritas¯
    Cyclone Lids
    Dust Filtration Bags
    Dust Filtration
    Bags
    Universal Vacuum Adapter
    Universal
    Vacuum Adapter
    Clear Dust Collection Hose
    Clear
    Dust Collection
    Hose
    Self-Cleaning Blast Gates
    Self-Cleaning
    Blast Gates
    Bridge Hose Clamps
    Bridge
    Hose Clamps
    Loc-Line¯ Dust Collection System
    Loc-Line¯
    Dust Collection
    System
    Magnetic Dust Chute
    Magnetic Dust Chute
    Dinosaur
    foolish men call Justice....
      IMERC | Oct 28, 2008 07:18am | #5
      that's $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
        Dinosaur | Oct 28, 2008 08:44am | #6
        Depends on how big the shop is. And he doesn't need all of that stuff.
        Dinosaur
  3. MikeHennessy | Oct 28, 2008 02:35pm | #7
    I think with a 2-1/2" vac, you're pretty much limited to using PVC or ABS since you don't really have enough air volume to go with a 4" or 6" duct. The static charge on the plastic is only an issue if you touch it, and that can be reduced by providing a ground path as you suggest.
    That said, any ducting will reduce your vac's efficiency. You may be better off just pluggin it in to each tool as you use it to keep the run as short as possible.
    Mike Hennessy
    Pittsburgh, PA
      IMERC | Oct 28, 2008 02:49pm | #8
      3" snaplok???
      1. MikeHennessy | Oct 28, 2008 03:07pm | #9
        "3" snaplok???"
        I was thinking the smallest was 4", but I see they do make 3".
        I still think putting in a duct system would render that shopvac all but useless tho'.
        Mike HennessyPittsburgh, PA
          IMERC | Oct 28, 2008 03:12pm | #10
          with the snaplok he's got something that's 100% reusable and easy to reconfigure...
          he's also making do it seems..
          the days of a shop vac as dust collection are long gone thank goodness...
          way too many negatives even if he uses a solids/heavies seperation tank...
          IMERC | Oct 28, 2008 03:13pm | #11
          and tape is all he needs to hold it together....
          1. MikeHennessy | Oct 28, 2008 03:24pm | #12
            I was gonna say he'd still need blast gates and I doubt you can even get 3" blast gates, but after doing a search, I find I would have put my foot in my mouth again! Saw some for $8 each. Who knew?
            I still think moving the vac to each machine is the better plan. Heck, I have a real DC and that's what I do since I rarely use more than one machine at a time. I just plug the hose into the collector at whatever machine I'm using.
            IMERC | Oct 28, 2008 03:29pm | #13
            make his own blast gates.. scrap... bunch less than 8$$
            go cyclone...
            http://www.diynetwork.com/diy/hi_tools/article/0,,DIY_13936_3449727,00.html
            http://www.diynetwork.com/diy/shows_dit/episode/0,,diy_14298_33653,00.html
            http://www.lumenlab.com/forums/lofiversion/index.php/t9315.html
            http://www.diylife.com/2007/10/31/build-the-ultimate-dust-collection-system-with-a-cyclone-seperat/
      Sphere | Oct 28, 2008 07:20pm | #16
      In my teenage shop way back when, I used carpet tubes. Ya know the 3" diam. cardboard? Free from a carpet store.
      That and a few Alpo cans and flexible dryer vent hose, and I was good to go. I made the blast gates out of masonite sliders in a plywood holders..kindof a sammich. I made to connection collars out of the dog food cans and hot melt glue.
      I was pretty proud of it. I had the sears (LOUD) vac going into a 55 gal. Fiber drum/cyclone with pvc ells. The vac would collapse teh drum if I had all the gates closed, so I made a stack of 3 1x1" and a screw in the center, opened up like wheel spokes, kept the drum in shape when using just one gate.Spheramid Enterprises Architectural Woodworks
      http://www.youtube.com/watch?v=Dj_oEx4-Mc4
      1. MikeHennessy | Oct 28, 2008 07:27pm | #17
        LOL! I'm afraid to ask what you've upgraded to -- old copper downspouts or perhaps salvaged conduit? ;-)
        Hmm. Now that I think on it . . . .
          Sphere | Oct 28, 2008 07:34pm | #18
          Galvanized DS, salvaged from a job..LOL
          Right now, the shop is temp and (has been for 4 years) I am just running 4'' DC hose, and neck down to 2" for someplaces. I only have 2 4" lines on the Y.  Chinese DC , two bagger.Spheramid Enterprises Architectural Woodworks
          1. MikeHennessy | Oct 28, 2008 08:02pm | #19
            "Chinese DC , two bagger."
            And based on some of your prior posts, both them bags are filled to the top with PVC "snow". ;-)
            Sphere | Oct 28, 2008 08:07pm | #20
            Not lately , luckily.
            I did make a huge mess out front this AM , planning a bunch of cypress..took the planer outside, cuz of the lengths I had..shop too small..arrghh.Spheramid Enterprises Architectural Woodworks
          3. ted | Oct 28, 2008 10:40pm | #24
            Tell him you don't want lung disease or cancer (wood dust has been identified as a carcinogen) by the age of 20. That should perk his ears up.
  4. peteshlagor | Oct 28, 2008 03:40pm | #14
    Mebbe I've been misled, but as I understand, it's IN the pipe, not around it.
    1. andyfew322 | Oct 28, 2008 10:30pm | #22
      what?
      I'm just sayin'
      1. peteshlagor | Oct 28, 2008 10:40pm | #23
        Your copper ground wire.  As I understand, it's supposed to be inside the PVC tube for static control.
        http://billpentz.com/woodworking/cyclone/ducting.cfm#StaticElectricity  (about 80% down the article in the section entitled, "Static Electricity."
        And read this too.
        http://home.comcast.net/~rodec/woodworking/articles/DC_myths.html#inside
  5. ted | Oct 28, 2008 05:49pm | #15
    Get your parents to buy you a dust collector or wish one for christmas. Tell them it is for the protections of your health. Or save your pennies. In the meantime I'd save the money and simply hook the vac to each machine as you use it. Why invest in something now you probably won't be happy with in a year.
    1. andyfew322 | Oct 28, 2008 10:29pm | #21
      HA, my dad laughed at me when I asked for my current vac, anyways I don't even have the room
      I'm just sayin'
Choosing a Paintbrush
  • The New Old Colonial
