What is level?
alaskafour | Posted in General Discussion on January 28, 2007 05:36am
The other day a friend asked me “if something was considered level what’s it level to?”  I told him I didn’t know but as long as the bubble were between the lines I was happy.  Afterwards, I wondered!  What is level?  What determines level?
  1. Reyesuela | Jan 28, 2007 05:49am | #1
    Perpendicular tot he gravitational pull of the earth.
    Ideally, it would be PARALELL to a tangential line to the earth's surface if it were perfectly round...
    Edited 1/28/2007 4:21 pm ET by Reyesuela
    1. segundo | Jan 28, 2007 06:51am | #4
      isn't it parallel to the tangential line, not perpendicular, at the exact spot where the tangent and the sphere meet?
      1. Pierre1 | Jan 28, 2007 08:30am | #6
        Yippers. Parallel to the tangential line, which is perpendicular to the earth's radius.
        To the eye, a bubble stick will parallel the horizon on a large body of water.
        1. mcf | Jan 29, 2007 05:55am | #37
          The horizon is curved. If you hold a straight edge up to the horizon you can see the curvature of the earth. Thus it is impossible to parallel the horizon
      2. Reyesuela | Jan 29, 2007 12:21am | #26
        Pfffth. THat's what I mean. Sorry!
        1. segundo | Jan 29, 2007 01:09am | #27
          i knew you knew, just a typo.
  2. segundo | Jan 28, 2007 06:41am | #2
    perpendicular to plumb!
  3. DanH | Jan 28, 2007 06:49am | #3
    Level is perpendicular to vertical.
    1. highfigh | Jan 28, 2007 09:23am | #7
      Plumb, not vertical. Plumb is aligned with the gravitational pull and level is perpendicular to that. A water level is most accurate since a bubble level with markings can be shifted in the frame of a "level". Also, if a tall building is compared to another one more than a few hundred feet away, they may be plumb at their own location but the sides won't be parallel."I cut this piece four times and it's still too short."
      Edited 1/28/2007 1:25 am by highfigh
      1. blue_eyed_devil | Jan 28, 2007 03:03pm | #9
        I seem to have that trouble even when the walls are a few feet away lol! Now I have an answer though!
        blue"...if you just do what you think is best testing those limits... it's pretty easy to find exactly where the line is...."
        From the best of TauntonU.
        1. highfigh | Jan 28, 2007 07:41pm | #19
          "I seem to have that trouble even when the walls are a few feet away lol!"I didn't want to mention the problems with that. I have a friend who's an architect and when he was still working in Green Bay, he went to check on a job. finding that one 10' high wall was 8" out of plumb. He called the framer to fix it and they showed up with a chain saw and sledge hammer. Fired them on the spot.
          1. fingersandtoes | Jan 28, 2007 07:54pm | #20
            "They showed up with a chainsaw and a sledge hammer. Fired them on the spot."
            He shouldn't jump to conclusions. Maybe the guy was just going to visit his Mother-in-law.
          2. highfigh | Jan 28, 2007 08:29pm | #22
            "Maybe the guy was just going to visit his Mother-in-law."Wouldn't he have had a chainsaw and shovel, instead? Or, a trencher, excavator, etc?
    2. wood4rd | Jan 28, 2007 04:16pm | #10
        plumb/level   vertical/horizontal
      1. DanH | Jan 28, 2007 04:26pm | #11
        So you're saying that level is parallel to the horizontal?
        Edited 1/28/2007 8:27 am by DanH
        1. wood4rd | Jan 28, 2007 05:08pm | #12
          Yes.....is this a trick question?
          1. DanH | Jan 28, 2007 05:58pm | #13
            Well, which is it?
          2. wood4rd | Jan 28, 2007 07:07pm | #17
              Well, the last time I checked they called my Stabila's levels... not horizontals..so I'm going to go with that.
  4. bobbys | Jan 28, 2007 06:53am | #5
     not to mess everything  up, i read once if they built a really tall building theres a difference between a plumb bob and a level used for plumb, maybe the center of the earth as it goes up, Now i cant remember but it was strange
  5. CarpentrySpecialist | Jan 28, 2007 12:58pm | #8
    Tell your friend that building "level" is quality work and "level to what"  is a mute point.
    Best to you and yours, Chris.
    Some say I know too much.
  6. DavidxDoud | Jan 28, 2007 06:20pm | #14
    What is level?
    well, 'level' is a noun - it's not a person,  so it must be a 'place' or 'thing' -
    in carpentry,  I think I would describe it as 'elements of construction at right angles to plumb' -
    it would also be an ideal,  to be closely approached,  but never achieved -
    in science/mathmatics,  it has other specific specific meanings -
    'plumb' determines 'level'...
    ....just my take on it....
    "there's enough for everyone"
    1. DanH | Jan 28, 2007 06:23pm | #15
      Level is what everyone here is half a bubble short of.
      1. StanFoster | Jan 28, 2007 06:51pm | #16
        I did the math on this for fun.  If you take the circumference of the earth as 25000 miles...then divide that into degrees.....you get 69.44 miles per degree.  Further reducing this to one minute of degree,,,this is 1.157 miles.  Finally one minute of degree on the earths surface is 101.85 feet
        So for fun...lets round that off to a building that is 100 feet long.  If it has ten foot tall walls...the outside walls if erected exactly vertical will be one minute of angle out of parallel with each other.
        So if Blue were framing this....the math shows that the top plates will be slightly wider than the bottom plates.  Blue would have to make the top plates  0.0056 inches wider.
        This of course of course is negligible...but it still is about 6 thousandths of an inch...something to talk about around at donut time.  If you are building only a 50 foot wide structure..then its only 3 thousandths of an inch out of parallel.
        The Golden Gate bridge actually had to take this into account...as I dont know what the span is between the towers or their height...but it was a few inches that they had to allow for the towers being out of parallel that far apart.
        Stan
        Edited 1/28/2007 10:52 am ET by StanFoster
        Edited 1/28/2007 10:54 am ET by StanFoster
        1. brownbagg | Jan 28, 2007 07:14pm | #18
          that also why most lazer are level to 1/8 inch in 100 feet. the lazer light not beneding so at distances it over shooting the curver of the earth.
            BruceT999 | Jan 28, 2007 08:02pm | #21
            "that also why most lazer are level to 1/8 inch in 100 feet. the lazer light not beneding so at distances it over shooting the curver of the earth"You're close on that one, actual curvature of earth is 1 inch in 592 feet, making a perfect laser level's inaccuracy about 1/6" at 100 feet.http://www.marineplanner.com/calculators/hordist.cfmBruceT
          2. highfigh | Jan 28, 2007 08:30pm | #23
            Done some surveying, have ya?
          3. pm22 | Jan 29, 2007 04:07am | #35
            The number is use is 466 feet 10 1/2 inches. I think your figure is way out of line.
            Nevertheless, this is still a significant problem.
            Another poster mentioned that a plumb robert will be deflected by a nearby mountain. Actually, the mountain is lighter than the valley since otherwise, how would it float about the earth's liquid mantle?
            ~Peter
            Coming soon: "Airplanes of the NFL"
            jonblakemore | Jan 29, 2007 07:03am | #38
            I agree with your figure.I have a spreadsheet that I use (I know, I'm a nerd) to calculate the distance that a level plane is from a perfect sphere with a radius of 3,963 miles.When I input 466.875 (466' 10-1/2") my drop is exactly 1/16".
          5. highfigh | Jan 29, 2007 05:58pm | #40
            Mountains aren't lighter, they're usually caused by tectonic uplift, as in inward pressure on two sides of the plates and one slides under the other, buckling and lifting it until the pressure is sufficiently relieved.
          6. Reyesuela | Jan 30, 2007 02:40am | #50
            I think pm got confused--continental plates are lighter than oceanic plates. But mts aren't lighter than valleys.
          7. dovetail97128 | Jan 28, 2007 09:39pm | #25
            Unless of course you are using the lazer over a large heated surface that causes the air to have "Heat Waves" .
            Tried a lazer over a 675' x 300' slap set up (set the lazer at the midpoint of the 675'). The sun heated air caused the lazer beam to bend around so much that every time we tried for a reading it would come up different. Ended up shooting grade before the gravel got hot and then again in the evening after it cooled down.
            Beam would bounce and bend on the "waves".
            Had the same problem with optical transits. And not between the "lines"... but "Exactly Centered" between the lines
            with vial levels
            Edited 1/28/2007 2:23 pm ET by dovetail97128
  7. rwjiudice | Jan 28, 2007 09:21pm | #24
    "level" is determined by the bubble being between the 2 lines.
    Gotta go now..... working on the meaning of life.. i'm close....
  8. alaskafour | Jan 29, 2007 01:13am | #28
    Thanks for taking the time to share your knowledge and wisdom on my recent post "What is level?"  I've never given that question much thought but, I now look at "level" in a different prospective.  Thanks again.
    1. DanH | Jan 29, 2007 01:45am | #29
      As has been noted (in the posts that aren't simply being silly (now who would post something silly?)), "level" is really most accurately described as perpendicular to plumb. And "plumb" is the angle described by that theoretical infinitely thin, infinitely light, uniform cord suspending a weight in the absence of air movement.But the earth is not uniform in diameter and composition, so a plumb line near a large mountain, eg, will have it's weight pulled ever so slightly toward the mountain. This means that a plumb line doesn't always point through the theoretical center of mass of the earth, and two plumb lines opposite each other on the earth will not necessarily point towards each other along a common line.Thus "plumb", and hence "level", is a localized and somewhat irregular phenomenon, even after you take the curvature of the earth into account.(Not that this means anything for practical construction, but the effects are significant enough to be measured with relatively unsophisticated laboratory setups.)And, of course, if one were to take relativity into account then it would really get weird. My crude understanding is that "plumb" would still be plumb, to the next order of approximation, but "level" would start to get ugly.
      1. highfigh | Jan 29, 2007 02:06am | #30
        Plumb = "square to the world". Level is perpendicular to that. You could also say that level is square to plumb and theoretically, level would be parallel to the world, which we all know is impossible since the world is roughly spherical. Parallel to the world would them make level concentric to the world. "I cut this piece four times and it's still too short."
        Edited 1/28/2007 6:09 pm by highfigh
      2. segundo | Jan 29, 2007 02:09am | #31
        water, protected from the wind and allowed to "settle" will get you as close to level as you need to be. the pyramids are proof that man has been clever for a long time.
        you are correct that the effects can be measured with unsophisticated equipment, the slightly above average scribe would have been able to do it over 200 years ago.
        as a production framer working in plumb and line crew it wasn't long before i didn't need a string to line walls, like for an apartment or condo type frame with a long straight ext wall. the egyptians used wedges and sighting to survey. anyway now its a curse, i can see when stuff is out of level or plumb just a little and it bothers me. i have to level pictures in public places etc. kinda wish i never learned that skill.
        1. bobbys | Jan 29, 2007 03:50am | #33
          yes when i framed back east i went  on the plates as we plumbed the walls useing just my eye, amazing some  carpenters dont believe me as they break out srtring lines, i dont know that its bragging just something i was good at, i cut the rafters so it was in my intreast to have it plumb
          1. blue_eyed_devil | Jan 29, 2007 04:04am | #34
            Plumb really wouldn't be affected on an end gable wall. Both walls would be theoretically out of plumb the same amount and the span would remain the same. The rafters would fit just as well on a plumb pair of walls as on an out of plumb pair of walls.
            Perhaps you better get back  there and put the level on that stuff.
            I'm all for eyeing things and making them look good....I"m just pointing out that the rafters only need things to be paralell, not plumb.
          2. segundo | Jan 29, 2007 05:21am | #36
            i think he (bobbys) is referring to lining the walls when he says plumb the walls in his post.
            i would always put the level in the corner even if it looked right, and then if you just sight between the two plumb corners (just like you were aiming if your a shooter) and you can "sight" the "line" or "plumb the intersections of walls"
          3. bobbys | Jan 29, 2007 07:22pm | #42
            Yes that is what i meant, plumb the corners with a level then sight down the wall with eye while other guys push or pull to straighten the walls, On another note a carpenter friend built a house and he is very good i might add but his window looked out of level just a tiny bit, I walked around and it jumped out at me, He laughed and said he was off a little and did not catch it , i must be the only person in the town that would catch that by walking by.
          4. Reyesuela | Jan 29, 2007 11:46pm | #46
            Hehe. My capenter thinks I'm a freak of nature because I can glance at a piece of lumber lying on the ground and tell whether it's straight. I just hung two pictures 12' apart. One of them is 1/8" lower than the other. It bothers me. :-) The fireplace in my parents' house is nearly an inch too far to the left to be centered on the wall, too. The last house that I've been in that was actually "dead-on" was the one I just bought!
          5. Piffin | Jan 30, 2007 12:14am | #48
            LOL, there IS a thread discussing the pros and cons of obsessive-compulsive disorder in the Tavern.;)Not that I would know anything abouth things like that!
          6. fingersandtoes | Jan 30, 2007 06:32am | #56
            Whenever there is a piece on Harrison Ford's career, they always bring up that he started as a carpenter and that he has "perfect plumb". They always mention it in reverential terms. It always makes me uneasy for some reason.
            Edited 1/30/2007 3:40 am ET by fingersandtoes
          7. DanH | Jan 30, 2007 06:40am | #58
            That's odd, since his face is so crooked.
          8. gb93433 | Jan 30, 2007 06:44am | #60
            The earth is closest to an ellipsoid.
          9. Pierre1 | Jan 30, 2007 06:59am | #61
            An ellipsoid. Did you hear that Sphere?
          10. Ozlander | Jan 30, 2007 09:37am | #62
            Yep, fatter at the equator, the force of gravity is less there also.
            Ozlander
          11. ronbudgell | Jan 30, 2007 02:11pm | #63
            It's an oblate spheroid.
            Keep calm, Duane.
            Ron
          12. DanH | Jan 30, 2007 02:12pm | #64
            Actually, kinda pear shaped, I believe. A bit of a bulge at the top.
          13. Piffin | Jan 31, 2007 04:06am | #70
            I know he's not that well balanced - he's a left winger, LOL
          14. DougU | Jan 30, 2007 05:52am | #55
            Reyesuela
            I work with a guy that picks up a piece of off-fall.........maybe 11-12' long....he can lay it up on the miter saw stand without the use of a tape and consistantly cut it to within 1/2" of center each time, often times much closer.
            He hands me one and I'm tickled if I can get it to within 10", and thats rare!
            Some people just got it!
          15. DanH | Jan 30, 2007 06:35am | #57
            You mean cut it to half the original length? If so he's probably cheating and surreptitiously finding the balance point.
          16. DougU | Jan 30, 2007 06:42am | #59
            Yea, cut it in half. And I've seen him do it enough times to know that he's not balancing the wood.
            In most cases this wood is the end cut of rough sawn wood, not a nice even piece of wood to balance.
          17. segundo | Jan 30, 2007 01:01am | #49
            its a curse i'm telling you, you will never be able to get rid of it.
          18. Jer | Jan 30, 2007 03:13am | #51
            Worked for a lady once that had that same curse and she was the biggest control freak PITA I have ever worked for in my 30 years or so as a carpenter. She would have to have all the slot head screws in the house (including all electrical plates) have the slot running perfectly level, the Venetian blinds had to have the same reveal in every room, she would tell me that the cabinets that I just installed were not level and I would show her with a water level, a stick level, and a laser that they were dead on, but she still insisted they were out, so I would play her game and let her 'determine'what level was.Finally I had it, and when she would go out I would sneak around the house and set some of the screws just slightly on skew, or tip the pictures ever so slightly out of plumb, and 'reset' the blinds. She never said anything, so I don't know if she ever picked up on it.Her only saving grace was that she loved me and had more money than God.
          19. segundo | Jan 30, 2007 04:13am | #52
            reminds me of the old timer i subbed for one time, had a story about a lady who wanted her laundry room painted the same color blue as her broom handle
            painter went and picked up a coupla gallons of blue, when he got done with the room he gave the handle a fresh coat. after it was all dry the lady was comparing the colors and replied that looks excellent! almost an exact match!
          bp21901 | Jan 29, 2007 06:46pm | #41
          "water, protected from the wind and allowed to "settle" will get you as close to level as you need to be. the pyramids are proof that man has been clever for a long time."Come on....we all know the pyramids were build by aliens, not the Egyptians...
          1. Piffin | Jan 29, 2007 08:29pm | #43
            Is that on the level?
            I don't know, but you might want to square things up with the guys here if it isn't.
            I'm just never sure about these things ever since I fell out of the plumb tree and landed on my head.
            But at least I know gravity still works!;)
          2. DanH | Jan 29, 2007 08:31pm | #44
            That's what they WANT you to believe.
          3. Adrian | Jan 29, 2007 10:39pm | #45
            (bluegrass joke).....how do you know when you got the stage good and level? You get drool coming out both sides of the banjo-players mouth.
             Cabinetmaker/college woodworking instructor. Cape Breton, Nova Scotia.
          4. highfigh | Jan 30, 2007 04:34am | #54
            You know why it's a good idea to keep a banjo in your car?
          5. Adrian | Jan 30, 2007 10:38pm | #65
            No.....why's it a good idea to keep a banjo in your car???Cabinetmaker/college woodworking instructor. Cape Breton, Nova Scotia.
          6. DanH | Jan 30, 2007 10:43pm | #66
            It's good to have something to throw under the wheels for traction.
          7. DanH | Jan 30, 2007 10:44pm | #67
            And bagpipes don't work as well.
          8. highfigh | Jan 30, 2007 11:45pm | #69
            I like bagpipes. From a bit of a distance- they're pretty loud. I have a friend who does clinics for Fender Instruments/Amps and he was doing a master class at a local music store, talking about the different styles of players, and when he got to one in particular, he said that if you have evil spirits in your house, play the way he does, you can scare them off "and you will be as alone as you want to be", meaning that particular style is definitely not for everyone.
          9. Pierre1 | Jan 31, 2007 08:58pm | #73
            The bagpipes are great for holding sand or kitty litter though - keeps the truck clean inside.
          10. highfigh | Jan 30, 2007 11:41pm | #68
            It's a good idea to keep a banjo in your car so nobody will put another one in there.Perfect pitch = lobbing a banjo into a dumpster without hitting the sides. Before anyone tells me that they're offended, I like banjo music, especially when it's from people like Bela Fleck and a few others. I also like pedal steel, mandolin and various other odd instruments.
          11. Adrian | Jan 31, 2007 07:12pm | #72
            You know the definition of a gentleman?
            Someone who knows how to play the banjo, but won't.
            (I like banjo too....don't tell anyone. I also play mandolin)Cabinetmaker/college woodworking instructor. Cape Breton, Nova Scotia.
          12. ruffmike | Jan 31, 2007 04:17am | #71
            What's it mean when a banjo player has three women on his arm ?
            He got a new tattoo !                            Mike
          13. highfigh | Jan 30, 2007 04:32am | #53
            I thought the Ancient Egyptians WERE aliens.
        BillHartmann | Jan 29, 2007 03:28am | #32
        If you look at the dictionary they show several different means (as related to this subject).Both a plane perpendicular plumb and a tangent to the horizon. In some circumstances they can be sligthly different. But it only matter if you are trying to hit the moon from the earth without any course corections.They also us it to mean flat. And in construction level is very often misused when the question if flatness, such as laying flooring material..
      4. Brooks | Jan 29, 2007 04:32pm | #39
        It gets worse: The center of mass of the earth is not the center of the planet...
  9. Bruce | Jan 29, 2007 11:50pm | #47
    What water does when it's resting ...
    Bruce
    Between the mountains and the desert ...
  • Stop Ice Dams When Reroofing
  • Outdoor Lighting
  • Eichlers Get an Upgrade
  • Picture-Perfect Pergola
