what kind of insulation
redfox45 | Posted in Construction Techniques on October 29, 2005 04:35am
Im turning a garage into an apartment.
the building a slab with 10ft block walls&trusses
instead of furring the walls i built 2×4 walls &stood
them against the block, thinking i could insulate better.
a friend told me i shouldnt use fiberglass insulation
against block walls(moisture)if this is true whats best
to use in this situation?
  1. RW | Oct 29, 2005 04:57am | #1
    FG can work if you can keep it from wicking moisture. Thats one rationale for keeping stud walls stood out from the concrete or block. You can put a continuous VB on the back side and use unfaced batts in your bays. If you're already too late for that, consider closed cell foam.
A New Approach to Foundations
  • Why the FHB Summit Is an Industry Event You Don't Want to Miss
