what material to make a condensate drain
BarbaraD | Posted in General Discussion on July 21, 2006 08:08am
I’m about to install a mini split AC unit, and attached to the blower is a 2-foot hose for the condensation to drain.  Since my unit will hang on an interior wall, I need to add onto it (the drain line) and run it another 10 feet to the exterior wall where I can punch a hole and let it drip out.  But I don’t know what sort of pipe or tubing to use for the additional run.  The hose that comes with the unit is unique; it’s clearly got some insulation in it because it feels spongy.  It has an inside diameter of 5/8″.  I’ve looked over all the hoses and tubes at home depot and there’s nothing similar.  Then I went over to the electric dept and looked at that gray conduit.  I need something that can stand a lot of heat because it has to run through an attic where it will be quite hot.  Does that gray condiut stand heat?  If anyone has other suggestions, do tell.
    IMERC | Jul 21, 2006 08:36am | #1
    3/4" PVC with a T and hose barb for the drain hose to hook to....
    put the hose in the leg side of the T.... stub a short piece of PVC to act as vent...
    read the instructions and see if if the drain requires a trap.....
    if it does put the trap in after the T....
    WOW!!! What a Ride!
Two Ways to Test Windows
  • The New Old Colonial
