What size header?
MBaybut | Posted in General Discussion on July 31, 2006 11:24am
Hi,
I want to put an arch opening in a load bearing wall. The opening will be about 50″ wide, in fact, the wall itself is only about 68″. The building is a single story home. Any help appreciated.
Mike
  1. JohnSprung | Aug 01, 2006 01:27am | #1
    This sounds like an interior wall, right?  Take a look in the attic, and see what it might be supporting.  Is it holding up the ends of ceiling joists, or any roof load?
    50" is a nice short span, so you can way overbuild this header for not a lot of money  -  doubled 2x8's or even 2x10's.  If there's really no load on it, go with just 2x4's on the flat.
    The important thing is to keep any loads on the old wall supported while you change it to a header.
    -- J.S.
    1. MBaybut | Aug 01, 2006 04:16am | #2
      John,
      Thanks. It seems to support the centre of the roof span (ceiling joist). Where the wall ends and there's open space in the room there's a doubled up joist to the gable wall,only about 6' long. the rest of the centre of the house has the wll going to the other gable. Hope it makes sense.
      Mike
      1. JohnSprung | Aug 01, 2006 09:19pm | #3
        That sounds like a bearing wall.  Can you post pictures of it?
        -- J.S.
        1. MBaybut | Aug 02, 2006 03:20am | #4
          Here's a couple of pics. The first one is of the wall in question. The second one shows pic from the attic, you can make out the double joist which is spanning the opening to the right of the wall in the first picture.
          Thanks,
          Mike
Rescuing Old Hardware
Whether it’s already in your house or picked up at a flea market, vintage hardware almost always needs help.
