Where to install rigid insulation
intrepid | Posted in Construction Techniques on March 27, 2007 09:22am
I’m building a new home and would like to add 1″ or 2″ sheets of rigid insulation to the exterior 2×6 walls to provide more insultation.  I will be using cement fiber siding. Is this feasible?  If so, what is the best sequence of application?:
1) studs, rigid insulation, sheathing, house wrap, cement fiber siding
2) studs, sheathing, rigid insulation, house wrap, cement fiber siding
Or
3) rigid insulation (applied to interior), studs, sheathing, house wrap, cement fiber siding?
    diddidit | Mar 27, 2007 09:26pm | #1
    Search for Mooney Wall, or go through the Adverse Conditions thread:
    http://forums.taunton.com/tp-breaktime/messages?msg=67972.1
    did
    Cure Diabetes - Whitefish, Montana, 2007!
    Donate Online!
  2. paul42 | Mar 27, 2007 11:21pm | #2
    studs, sheathing, house wrap, rigid insulation, furring strips, cement fiber siding
    1. intrepid | Mar 27, 2007 11:47pm | #3
      Have you applied insulation as you recommended with good results?
      What are the recommended dimensions of the furring strips?
      Finally, if I used a 3D house wrap like that featured in the current issue of Fine Homebuilding, could I avoid the furring strips?
      Thanks for your advice
  3. Piffin | Mar 28, 2007 12:19am | #4
    The sheathing must be directly on the studs and in your climate the foam should be on the interior side of the studs.
    So from inside out -
    paint
    SR
    Strapping
    Foam
    2x4studs
    sheathing
    housewrap
    siding
    paint
    1. intrepid | Mar 28, 2007 12:56am | #5
      What is the purpose of the strapping?  Couldn't I place the SR against the rigid insulation?  Or maybe the strapping is providing a cavity for the wiring so I don't have to puncture the insulation for outlet and switch boxes?
      Thanks for your input.
      1. Piffin | Mar 28, 2007 01:22am | #6
        You CAN place SR directly on the foam, but it gets tricky hitting studs with the screws then
        1. karp | Mar 30, 2007 08:34pm | #10
          Sorry, what is the sr? drywall?
          1. ravz | Mar 30, 2007 11:02pm | #11
            yes, drywall = sheetrock = sr
          2. karp | Apr 02, 2007 03:07pm | #12
            Thanks, feel kinda silly to have asked. Have seen d.w. , g.b. , gyp. , never sr, but ya think I coulda figured that one out.
  4. woodroe | Mar 28, 2007 01:31am | #7
    Have you considered using a polyurethane spray foam insulation in the stud bays? Urethane has a higher R value, fills and seals the stud bays completly. No rigid foam, no strapping. By the time you buy and istall the foam and strapping I think you would be $ ahead. Especially considering you would have none of the structural concerns with foam sheathing, no odd size jambs for doors and windows, electrical box mounting issues etc.
    1. intrepid | Mar 28, 2007 01:57am | #8
      I was hoping to reduce thermal conductivity through the studs by adding a veneer of insulation.  But, like you mentioned, it may not be worth the extra $ and aggravation.
      1. Piffin | Mar 28, 2007 04:40am | #9
        It is definitely worthwhile if you are using FG batts for your other insualtion
Picture-Perfect Pergola
