I’ve become farsighted in my middle age.
I’ve been wearing reading glasses for almost 2 yrs……..starting to wear them at work, but it’s not the right tool.
Last visit, Dr. suggested cabinetmakers spectacles…tri focals…….look through the middle, look up or down for close up.
I didn’t have time to visit the opthamologist that day. I would like a combo safety lens with the prescription in there……..
What do you wear, and does anyone have experience with what I’m talking about??
Eric
Every once in a while, something goes right!
None of us have any problems, Firebird. Must be your arms are getting shorter.
Duluth Trading .com has a few safety glasses with reading inserts for you oldtimers.
Get the surgery.
Who Dares Wins.
>>Get the surgery.
Talk to me Gunny...you're not talking about Lasik are you?
EricEvery once in a while, something goes right!
Yes I'm talking about Lasik. I don't think they can do anything for your close up problems but they can fix your far away problems. Stan Foster has had it. Personaly I haven't I wear contacts and get along fine. But as soon as I come across the cash laying around I'm getting lazered.Who Dares Wins.
yeah.........maybe I screwed up the far near thing.......I can't see up close or to read.........far is no problem.
I don't think Lasik can correct this.
I don't either. I
'm starting to lose my up close too. I've always had problems with far, but upclose is a new game and it sucks.Who Dares Wins.
Lasik is only for distance correction.
But there are a number of different types of procedures, some of them for near vision.
And for some that do need distance correction one option is mon-ocular vision where the two eyes are tweaked differently. For some people that works fine.
If you can get used to bi- or tri-focals, that's great. Most people, especially men, just don't have the patience. Depends on your work habit and what kind of work you do, most of the time your working distance is further than your reading distance so try a prescription that is not as strong as your reading glasses might help.
Me? I was nearsighted to begin with so when I started to find that I got eye-strain and headache at the end of the day, I switched to nonprescription and now I am happy. I figure one day if I need reading glasses to see what I am working on, I may as well call it quit.
I'm with Gunner - my wife wore glasses as thick as coke bottle bottoms. Got lasered about 5 years ago and now she sees too well. I can't get away with anything anymore.
I invented quadfocals.
They are called "occupational lens."
I've worn bifocals for a few years with blended lens ( no line), safety lens...problem is close work that is above you...like crown molding.
To get in focus you have to tilt your head back to look thru the lower portion of the lens. A real pain in the neck. An occupational lens has a close lens added to the top...so when your working close and high...you only tilt your head up slightly and look thru the top portion.
Not to complicate things ...there's another type called "piano glasses" lately called "computer glasses" These have the close lens at the bottom as in a regular bifocal but the top of the lens is ground to and arms length focus. They aren't worth a hoot for long distance. Good for me for interior carpentry..doing a crown job right now...also I like em for small plumbing/ elect work.
Couple of other things....get the safety lens!!!
Side shields ...make my eyes sweat.
Invest in a bottle of cleaning juice.
Get the kind with the little nose pads...frame on nose is a poor fit and impossible to adjust...unless you wanna be Joe Cool Carpenter.
I use the piano type but you have to get used to the fuzzy look if you looking across the room..a pain for someone...I just live with it.
So I take it you've no experience with theses.
I suppose I could have the glass guy do a mock up for me to try.......took me a while to get used to the reading glasses. I flip 'em off and on alot.
I can't use these at work , so I'm doing a little research.
sucs gettin old.......
i wear varifocus.. infinite adjustment..basicaly the bottom is for close.. top is for far..
and anything in between.. the focal pointis what you are pointing your nose at..
i also wear the combination sie and top shields.. i put them on when i leave the house and switch to my regular varifocus glasses when i come home..Mike Smith Rhode Island : Design / Build / Repair / Restore
Just make sure the doc does not talk you into the focus he wants.
BTDT
I'm nearsighted. 20:400 correctable to 20:15. Those numbers mean
["My distance to read]:["Average distance to read]
I'm using bifocals now, but I've worn lenses since 1957.
My ideal lenses will have the top and bottom thirds focus center 6" past my palm. This will give me a band of clear vision from mid fore arm to hammerhead. I can read without glasses.
I want Comfort Cable earpieces. These are a stiff cable that wraps around the ear. It is the only system I have found that does not slip.
Screen type side armor to maximize ventilation.
SamT
I am about the same shape that you are in.
"Can you read the top line" - Yes, they always put and E up there so I assume that this chart is the same.
My problem is that I want to something real exactly I will take my glasses off, get my face into it, set the cut line or drill bit, hold it and slip glass back on and then do the operation.
I think for 2 reasons. One the nearsighted correction makes the item smaller. So taking them off it is much larger.
The other thing since I have bifocals then I have limited range of view in the bifocal area.
Flamingornith: Get trifocals & stop fighting the problem. BUT - when you do, spring for the extra sheckels for what they call "Executive" trifocals. The sections for mid & short range go all the way across the lens, as opposed to being a quarter sized section tucked in the lower inside corner. With these, you can continue to move just your eyeballs to see something off axis. You don't have to move your whole head. Much, much easier to get used to. I've been wearing them for years, and they are GRRRRRRREAT. (Pass the Frosted Flakes.)
Don
