Should the installation of a 200 amp panel cost twice as much as a 100 amp panel. Beleive the existing sevice is 100 amp (fuses)
Thanks’
Dan
Thanks’
Dan
depends on what has to be replaced.
It may not just be replace one panel with another
bobl Volo, non valeo
Baloney detecter
Just the panel or are circuits being installed too? Any new wire runs? Supply a few details.
Based on full replacement - from util head tie-in to breakers.
I think the larger wire, larger box, and more breakers might double the material cost.
However, I do not think that the labor cost should double, but might be about 50% more.
200 seems to be the sweet spot these days. They're not a lot more than 100's and a hell of a lot less than 400's.
-- J.S.
Hello again, not sure of all the details, question for a friend at work who was telling she was told a 200 am service would cost 1700 while a 100 amp service would cost 700, she wasnt sure if the price included any work from the pole to the house and or a new meter. How much work if any is needed from the pole to house when upgrading? By the she is near Altonna Pa
Thanks Dan
She should have the electrical contractor spell out exactly what is included with each proposal and ask questions until she is sure she know's what she is getting.
I don't know much about electrical work, though I'd be willing to bet the 100 amp option is a direct replacement of the panel and new breakers and reconnect, while the 200 amp option includes a new meter, weather head etc.
If she has 100 amp service and want's to upgrade to 200 it would require more work.
The price's are a little higher but do not seem terribly out of line from what we pay, but I'm in KS, not PA.
Sounds like you probably nailed the discrepancy in the 2 quotes.
My question is "Why does everyone feel they need a 200 amp entrance?" Most of us will never use 60-80 amps at any one time with out a larger house with electric heat of some sort!! We're just screwing up planning for power plants by indicating that we'll be using 150-200 amps in the future.....this drives power rates up by having plants idling a lot!!
Edited 7/11/2006 7:31 am ET by experienced
Is she changing over to have breakers instead of fuses? If so, and she's not adding anything new on, then 100A is ok I would guess. Later they could add a sub if needs be. Personally I like to upgrade to more. What about a 150?
The price sounds about right for the 200. There's more changes going on.
