I am looking for advice on how to insulate my house walls.
The house is a 109 yrs old farm house style.
2 story with full attic, roof pitch is about 5/12, and I do have access to the top plate from the attic.
It looks like there is a purline in each stud bay 1/2 way up each wall I can’t verify this on the first floor since there isn’t a place to look. I will use a stud finder to check this (the walls are 10′). The walls look like they are “balloon framed”.
Interior walls, floor, and ceiling are 3/4″ tongue and groove (not plaster and lath).
Exterior is vinyl siding over moulded lap-siding approx. 6″ exposure.
The way I see it, I could use “blown-in” insulation.
I could:
Access the 2nd floor stud bay top half from the attic (drill a hole in the top plate, cover the hole after insulating).
2nd floor stud bay bottom half by removing a vinyl siding strip, drill hole in lap siding.
1st floor bay top half either by: top of wall interior and cover with large crown moulding, or by removing a vinyl siding strip outside.
1st floor bay bottom half by removing a vinyl siding strip.
If anyone has any other suggestions to do this, please let me know.
Thanks for the help and expertise.
Jim
Jim, it sounds like you know just what to do. One caveat: check for blocking, commonly used for fire-stop in vintage houses such as yours. As you can imagine, you'll not fill the entire cavity if fire-stop is present. Good luck, DM
*Jim - If fiberglas, use Certainteed's Insulsafe - this packs densely and is very user-friendly (not scratchy).Have you looked at http://www.tripolymer.com? Possible alternative.Jeff Clarke
It looks like there is a purline in each stud bay 1/2 way up each wall I can't verify this on the first floor since there isn't a place to look. I will use a stud finder to check this (the walls are 10'). The walls look like they are "balloon framed".
Interior walls, floor, and ceiling are 3/4" tongue and groove (not plaster and lath).
Exterior is vinyl siding over moulded lap-siding approx. 6" exposure.
The way I see it, I could use "blown-in" insulation.
I could:
Jim
