2 mud floor questions
mick182 | Posted in Construction Techniques on March 5, 2011 11:11am
I am preparing to float a bathroom mudfloor which is 12′ x 9′ and I have a couple of questions. The exising sub floor is sound and pretty level.
(#1)  how do I calculate the amount of sand and p. cement necessary to cover aprox. 110 sq. ft. at aprox. 3/4″-1″
(#2)  what type of sand from the home centers can I use for the mix? (i.e. fine play sand, all purpose, etc.) I ask about sand from the home centers is because there is nowhere around to otherwise get sand, and home center is right next door. I was told that the play sand was acceptable, but want to get an experts opinion.
mick
  1. calvin | Mar 06, 2011 06:39am | #1
    Mick
    Here' s some info on the process.
    http://www.johnbridge.com/how-to/deck-mud/
    Depending on the size of he bag available-you'll probably need one bag of Portland ( if 90 lb bag).
    The total mix will be about 9 cu.ft (if 1728 is the number of cu. inches in a cu ft./then dividing that into the total inches in a 9x12 area @ 1" thick).  If the play sand tells you the volume on the bag-you're in luck.  If not,  lay it on the floor and guess the amount in that bag.
    The mix ratio is 5 parts sand / 1 part portland.
    John Bridge forum says ok to play sand., but take a look at the explanation.
    1. mick182 | Mar 06, 2011 07:35pm | #2
      thanks for info Calvin
