24v and 120v – how close together?
JTC1 | Posted in General Discussion on April 4, 2007 03:20am
Best practice question:
I am building 3 closets for a customer.  The closets have 2, 3 and 4 doors; set with a minimum distance between doors.
After framing, but thankfully before drywall, the customer has asked for door jamb switching of the flourescent closet lights configured so that all of the light(s) in the closet come on by opening any one door into that closet.
Line voltage jamb switching is not feasible due to the spacing of the doors.  I have located low voltage jamb switches from Edwards and relay / transformers from Grainger which will handle the needed arrangement.
There will be multiple runs of 18-2 thermostat wire (switch manufacturer recommended) between the jamb switches and the relays (attic) and a 14/2 Romex run running essentially along the same path to each closet.
Is there any rule of thumb / code / performance issues which I should be aware of as to separation of the 120v and 24v wiring.  Should they be kept 6″ apart? A foot? or can they run in the same hole bored through a joist? I understand the separation issues at junction boxes – my question just pertains to the wire runs.
I can make everything work properly on a bench, just want to be sure the same configuration will work properly once it is behind the wall!
Thanks in advance.
Jim
Edited 4/4/2007 9:25 am ET by JTC1
  1. VAVince | Apr 04, 2007 03:30pm | #1
    Should not be an issue as far as the circuits working. There may be a code problem if you pull the cable thru the same hole.
  2. JohnD1 | Apr 04, 2007 04:46pm | #2
    I don't have the National Electric Code available, but as I recall the rule is this for putting low and high voltages in the same vicinity:
    • The low voltage circuit has to be related to the high voltage, so a low voltage system controlling lighting would apply.  (A telephone or doorbell wiring does NOT apply.)
    • All wires must be insulated to the highest voltage.
Balancing Density and Privacy in Los Angeles
Four 2200-sq.-ft. detached homes provide flexible open-plan housing on this Los Angeles block.
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
  • Podcast 547: Basement Insulation, Historic Preservation Resources, and Shipping Container ADUs
  • Podcast 547: Members-only Aftershow—Fine Homebuilding House memories
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
