Hey Fellas, Framing my garage this weekend 22×22 with scissor trusses (got em at a 1/3 the cost) they were a misordered item. 8ft walls. Is there a big difference in using 2×6’s or should i just use the 2×4’s and not assume the added cost? What would you do? Will it cost me much more?
Thanks, Lou
Mines the same size, 2x4 framing, no trusses, no sheathing, just paper under redwood claps. Still standing after 40 years. Might be better if it was braced or sheathed, but it still is straight.
Aside from cost there will be a significant difference in weight which you may wish to consider based on available labor.
2x6's came in to play in residential mainly for the purpose of adding insulation I believe.
[email protected]
Is it gonna be insulated and heated?
Are there other door(s) besides the big door? Windows?
Finished inside?
If you use 2x6 walls with scissors trusses that were meant for 2x4 walls, it's gonna be a little weird right where the ceiling and wall meets, but shouldn't be a big deal.
8' walls are a little low for a garage... depending on if you have masonry/etc stem walls below the framed walls and how high the stem walls are... What size is the big door (s)?
depends....
i like 10ft even 12ft walls for a garage if it won't look weird... you can store a ton of stuff up off the floor with higher walls...
2x6 walls do give you a ton of places to put shelves between studs... even gal paint cans will fit... all depends how you use the space and how you plan to finish it...
extra cost might not be worth it if it's just a place to park a car... won't be stronger or more valuable 2x6 vs 2x4
if i was going 10-12 ft... and 24" centers i'd go for the 2x6 no real reason other than it'd make me feel better... and give me more options later
at 8ft... i'd use full 8ft with plates that'll give you a little extra clearance for an overhead door and future electric closer ...
p
Lou,
2x6 @ 24" o.c. will cost you little more than 2x4 @ 16" o.c.
IIRC the difference in bd.ft. amounts to roughly one plate around the perimeter.
"Poor is not the person who has too little, but the person who craves more."...Seneca
Personally, 9' walls will make more difference than 2x6, in terms of usability of the space. If you're insulating, the 2x6 will be a bit cozier but you shouldn't have any issues with either as far as structural integrity or installing shelves.
