does code permit 2×6 headers for a 3′-0″ door in a gable wall with a truss roof?
Some do. Depends on your local code inspectors/authority.
Politics is the antithesis of problem solving.
arvel ,
What type truss is on top of the wall ?
If it is a true truss than you need no header as the truss is carrying the load.
If it is what we here call a "gable end truss" it is non load bearing in terms of spanning anything and you need a header.
"Poor is not the person who has too little, but the person who craves more."...Seneca
yea it's a gable end truss with vertical 2x4's turned the 1 1/2" way.It really doesn't function like a truss. I was hoping to avoid a 2x10 header since I only have 9 3/4" to top plate and a wire running just below the top plate.
Not an engineer. I would use a 4x 6 if I had one, assuming 2x 4 framing. I believe a 4 x 4 would handle the span easily though.
Last time I looked a 2x10 was 9.25 inches. If you have 9.75, you may be ok even with the wire.
2x8 would be 7.25 if I misunderstood what your 9.75 was covering. If you included a 1.5 top plate in it.
Ron
So why not go with 2x8s? Why 2x6?George Patterson
I think a 2x10 header is required on exterior load bearing wall, according to IBC 2003. I have built a sandwich header, 2x10-1/2"strips-2x10. I put a groove in top of header, leaving 1 1/4" wood in front of wires as per code. We'll see what inspector says. Thanks for all your input.
IMO, a good solution.
Personally, the minimun size header I will use is 2x8. On some tear-outs, I've seen 2x6 headers deflect as much as an inch. If I recall correctly, the span was 56" over a window in the perimeter wall, main floor, bungalow. So, in that instance, the header was over-spanned but it showed me how much movement can happen. Another reason not to play Engineer.
Pends'
Is door in the top or only floor?
Is it a gable end truss (looks like a standard rake wall when viewed from inside attic)?
Jim
dbl 2x6 w a steel flitch plate?
"Even if embryonic stem cells are absolutely good for nothing at all how can anyone in good conscience be against using them for research given that they are going to be destroyed anyway"? J.Hayes
http://www.john-lennon.com/imagine-neilyoung.ra
Double 2x6s with a layer of 1/2" hardwood plywood in between.
