3 electrical code questions
Soultrain | Posted in Energy, Heating & Insulation on November 2, 2006 03:17am
1)  When calculating for box fill, does a double light switch (2 switches on one unit) count as 1 device or 2?
2)  Do cable stackers count for securing NM cable w/i 8″ of a plastic box?
if not, then
3) is it permissible to secure two 14-2 cables under the same staple? (side by side under a large SE staple – not stacked on top of each other)
All responses (including snide remarks) are appreciated 🙂
  1. renosteinke | Nov 02, 2006 03:41pm | #1
    One mounting strap = one device.
    The "trees" are counted as support.
    Two cables under one staple is generally allowed; however, you are forbidden to place the cables so that the staples press against the outside edges; they must be laid flat.
    BillHartmann | Nov 02, 2006 03:44pm | #2
    "1) When calculating for box fill, does a double light switch (2 switches on one unit) count as 1 device or 2?"
    1 and the same for a double receptacle (the common duplex).
    The code does not count devices at all. It counts Yokes (or straps).
    "2) Do cable stackers count for securing NM cable w/i 8" of a plastic box?"
    It reads "secured by staples, cable ties, straps, hangers, or similar fittings". Also a hole is a joit or stud is acceptable. So unless the approval of a stacker said otherwise it should work.
    "3) is it permissible to secure two 14-2 cables under the same staple? (side by side under a large SE staple - not stacked on top of each other)"
    You need to check the approval. See the box. IIRC the 5/8" legs are only approved for one. But the those with 3/4" legs are approved for 1 or 2 14-2 or 12-2.
      Soultrain | Nov 02, 2006 04:52pm | #3
      Thanks guys!!
  • Smarter Stop Block
  • Square Walls Solo
  • Deck-Board Pry Bar
