3 tab shingles and pitch changes
tab1 | Posted in Construction Techniques on July 19, 2006 07:56am
Is there a general rule about using flashing at pitch changes on a roof, with asphalt shingles? In this case I’m going from 3.5 in 12 to 5 in 12.
If no flashing, do I want to try to get the last row of the lower roof’s shingles to finish at a particular point on the lower/upper roof?
Thanks.
Thon
  1. seeyou | Jul 19, 2006 01:36pm | #1
    Which way does the pitch change? I'm assumming the 3.5/12 is on the bottom. I normally just shingle thru that, especially with no more difference in the pitches than there is.
    If the pitch change is the other way (3.5/12 on top), I'd use flashing because its hard to get the shingles to bend that way and seal properly.
    Andrew Douglas: What have you been up to?
    Jim White: Killin' time... It just won't die.
    http://grantlogan.net/
    1. tab1 | Jul 19, 2006 03:21pm | #3
      Yes, the 3.5 is below.Thanks.
    BossHog | Jul 19, 2006 02:46pm | #2
    I think you'd be better off putting ice and wayter shield in there than flashing. If you're in snow country you'll have snow and ice piling up there.
    Finding an honest politician is difficult. Not nearly as difficult, however, as finding a black NASCAR driver
    hammer1 | Jul 19, 2006 05:18pm | #4
    At 3.5/12 you have a fairly flat roof and are close to the limit for standard asphalt shingles. Wind driven rain and ice and snow can get under such a flat application. I would recommend using an Ice and water membrane under the entire 3.5 section and running about 2' up the 5/12 section. You don't need any flashing with the shield.
Eichlers Get an Upgrade
Performance improvements for the prized homes of an influential developer who wanted us all to be able to own one.
