I just had 6 white oak logs sawn and I’m going to also have them kiln dried. Meantime, I;m also in the process of building a deck for myself. The framing would be treated lumber, but the thought hit me, what about using some of the oak as decking? Of course I would treat it with something (I’m not sure what ) but anyway what about it? Does anybody have any thoughts on this or any ideas? thanks wishbone 4444.
The Portascanner uses ultrasonic technology to isolate the smallest air leaks, making it easier to air-seal an enclosure.
White oak is pretty rot resistant and stable outside. I think it would be fine.
We have in our back yard a picnic table made of roughly 1-3/4" air-dried oak, 29 years old. Has never been painted, stained, or sealed. Looks real rough (eroded 1/2" in places) but still solid.
Note that the oak will warp and twist somewhat worse than other woods, though.
happy?
Rock on, if it is really well graded. FAS ( first and second slices) tend to be clear of defects on one face for 66% of the boards total net.
As you saw closer to the heart of the log, depreciation expounds.
When you install flat sawn timber, cull the spike knots lest they fall in a mid span and break an ankle..trust me .
I'd add that you could gather up a better use for white oak...?
Thanks, as for better uses, yes I probably could. But I was somewhat amazed at the amount of lumber I got from these six logs. I also believe in using native woods when possible.wishbone
Wishbone - I did a 8'x48' porch floor in 6/4 white oak, from trees I cut. It is 7 years old and no signs of decay. I installed it a little green and the gaps are kinda big. It is on the west side of the house so it gets all the wind-driven rain, etc. I was going for a rustic look, so I left it unfinished to gray over time.
With all that said, I wish I had used the wood for something nicer, since the oak was so pretty - I was just too cheap to buy decking at the time.
Treat every person you meet like you will know them the rest of your life - you just might!
Should have had it 1/4 sawn...beautiful wood. Jimmy...
Avoid using the sapwood. No decay resistance.
