Hello. I’m sure most of you have read my other Hardi questions but here is another question on the layout.
If I do the 6 1/4″ reveal on the siding I will come up 1 1/2 inches short between the top edge of the siding and the soffitt, this area will have trim anyway so I can cover the gap.
If I use a 6 3/8 reveal then I won’t have any gap between the top of the highest row of siding and the bottom of the soffitt. Is it okay to use a reveal other than what the specs. say? The specs. say that the siding must overlap by a min. of 1 1/4″ but a 6 1/4 reveal overlaps by 1 3/4 so theoretically I have a 1/2″ to play with. Is this correct?
Should I just stick with the 6 1/4″ reveal?
It is 3 am where I am, so I might be wrong, don't think so, but 1/8 ain't hurt that siding any!
I agree with frammer. An 1/8" won't matter.
And of course, if anyone questions, you could simply say that you were using the black diamonds on the tape measure!
<G>
I won't be laughing at the lies when I'm gone,
And I can't question how or when or why when I'm gone;
I can't live proud enough to die when I'm gone,
So I guess I'll have to do it while I'm here. (Phil Ochs)
the only probem with too much overlap is,it makes the lower edge stick out a little to far.
1/8 of a inch won't matter,if you was ovelapping maybe 2.5 inches it would start sticking out a little bit.
on my siding,kept everything level,but when we got to the top on the garage ,it was going to take a 2" strip. so i took a pc of 12" cut it at 9"so it would finish the row without a small strip. your eye cannot pick up that the top row is wider. being 10' off the ground helps hide it also
the older i get ,
the more people tick me off
Thanks fellas.
