I’m debating back and forth whether to frame with 2x6s or 2x4s. I plan on sheathing with 3/4″ to 1″ Thermax, insulating the attic to at least R-30, and carefully installing a poly vapor barrier. I rarely if ever see a new home framed with 2x6s here in S.W. Ohio. We have cool winters– temps average in the 30s and hot humid summers. Do you guys think the extra R-6 gained by using 2x6s is worth it, or is it overkill with the extra money going to better use elsewhere?
I'm debating back and forth whether to frame with 2x6s or 2x4s. I plan on sheathing with 3/4" to 1" Thermax, insulating the attic to at least R-30, and carefully installing a poly vapor barrier. I rarely if ever see a new home framed with 2x6s here in S.W. Ohio. We have cool winters-- temps average in the 30s and hot humid summers. Do you guys think the extra R-6 gained by using 2x6s is worth it, or is it overkill with the extra money going to better use elsewhere?
