In the attached diagram:
The notched posts A and B, is the A scenario “stronger” than B?
Is the “strength” added at point c?
or ………….?
WWPD
or ………….?
WWPD
Ford Motor Company slashes prices for some F-150 Lightning models to stimulate demand for electric vehicles (EVs).
What diagram?
View Image-----------------------------------------------------------------------------
WWPD
In all seriousness.....the secondary joist in "A" is actually snug to the post, yes?
FREE SPONGE BOB,SANCHO PANTS!
Yes snug
The post (4x4) HAS to be notched.
WWPD
Edited 11/13/2006 10:43 pm ET by Sailfish
Definitely a, I dont know why it did not come in your first post it still do'nt came up in the next one though
If you would remove the notch the post would be at least twice as strong!
Edited 11/13/2006 10:33 pm ET by T White
I don't see either option as much stronger than the other. I think both posts would be equally likely to sheer off, or bend and break at the skinny part near the top of the notch. The only advantage I can see is having the additional material near the other side of the post is it may help the bolts not pull through the post as easily.
Then again, if you were to use big enough washers that would be unlikely anyway. In all actuallity, the extra wood would mean extra shrinking and I think over time the post would be more likely to loosen up.
I guess I vote B for simplicity sake.
Wait, are we talking about deck posts for railings here? I guess form the detail I just assumed.
You need to click on the attachment.
Yes..."A" is definetly stronger than "B".
I doubt any real strength is added at "C" though.
What kind of strength?????
Load bearing of the joist/beam or whatever that is, or lateral strength of the post????
Or does point C mean compressive strength?
Say more about the situation. What R U trying to figure out?
The lateral strength of the post.
Is it stronger in a or b? Why?
It is for porch/deck railing posts.
Thanks.
WWPD
Edited 11/13/2006 10:58 pm ET by Sailfish
Edited 11/13/2006 11:05 pm ET by Sailfish
I don't think A was done for strength, I think it was done for wear. The added block may be acting as a washer, it can crack or get crushed some without affecting the integrity of the post. It may also be acting as a spacer if the bought all the bolts too long not realizing they were going to notch them.Rebuilding my home in Cypress, CA
Also a CRX fanatic!
No diff whatsoever in lateral strength
<No diff whatsoever in lateral strength>
I agree. Also, as someone else said, there may be an increase in B stiffness because two joists are loaded in torsion.
But, that might make the post in B slightly MORE likely to fail under a sharp lateral blow because the base is less resilient and lass able to absorb the shock.
Yep; just described the situation to DW as I took her her wake-up coffee in bed.
She laughed and said it would make the snapped-off post crisper across the break!
Forrest - you know that prank where you get on your hands and knees behind someone and your friend pushes them over you? Like that.
Thanks all.
WWPD
Another question would be is the added material shown in option "A" just blocking or is it another full length joist. If it were a full length joist, then the entire assembly may feel a little stiffer because you would be putting both of the joists in torsion instead of just one.
However, the post itself IMO is going to actually have the same bending or breaking characteristics in either condition.
If it's just blocking, I still say B, with the proper washers
Edited 11/13/2006 11:19 pm ET by xosder11
