AC question
ozbuilder | Posted in Energy, Heating & Insulation on June 26, 2005 02:29am
Last year i bought a new 3 ton goodman central heat and air unit. I am just getting around to installing it and wondered if anyone knew of a good resource for AC installation instruction.
Cheers,
  1. rez | Jul 05, 2005 04:24pm | #1
    bump
    A person with no sense of humor about themselves is fullashid
  2. BryanSayer | Jul 05, 2005 07:07pm | #2
    There is an online dealer of Goodman products, and I believe they have a video. I think they were in Indiana or Kentucky but I'm not positive. I lost all my bookmarks when I got a new laptop, but if you search enough on the web, you should be able to find them. You might start looking at these two:
    http://www.acdirect.com/index.php?source=google&group=8&campaign=11&keyword=heatingandairconditioning
    http://www.heatingandcoolingstore.com/
  3. junkhound | Jul 05, 2005 09:36pm | #3
    Also look at DESCO's site or their ebay site for info.
    I assume you bought a 'package' rather than 'split system'.  Even having to ask the question if you bought a split system is scary. If you don't have all the equipment, count on at least $500 worth of second hand tools needed to do a split installation (gauges, recover pump/tank, vacuum pump, oxy-acetylene, Nitrogen bottle, thermocouples, etc. , EPA license test, etc. )
      constantin | Jul 09, 2005 03:10am | #4
      I second your fears.Installing a split system is not for beginners. Granted, if you've been a HVAC tech all your life, have the tools, certifications, etc... oh right, you wouldn't be asking that question!Fact is, unless the connections are brazed, a tight vacuum pulled, etc. that the refrigerant will be contaminated with the remnants of flux, oxygen, and moisture. Even if you install a strainer, the system life and performance will be compromised.Perhaps this is the reason that Goodman specifically excludes internet-purchased systems from their warranty coverage. I'd do the same thing if I were them...
