ACAD 2000 Blocks
Hackinatit | Posted in General Discussion on October 8, 2007 06:25am
I just aquired autocad 2k for practice/learning. Have any of you a good source for house design/layout blocks?
Thank You
“Fortunately, the ideas of individual liberty, private property, freedom of contract and association, personal responsibility and liability, and government power as the primary enemy of liberty and property, will not die out as long as there is a human race, simply because they are true and the truth supports itself.”
Hans-Hermann Hoppe
    CapnMac | Oct 08, 2007 08:01pm | #1
    These are varying levels of "free"
    While you are about the web, go to dwggateway.com (that's two "g's") amd get their freeware for open any ACAD dwg and saveas any--this will help annoyances down the line.
    http://cben.net/
    http://www.cadmonkey.com/blocks.htm
    http://www.draftsperson.net/index.php?title=Category:Free_AutoCAD_Blocks
    http://www.cadopolis.com/
    http://www1.n16blocks.com/
    Now, fair notice--several of those are metric blocks in mm, some are in inches.  Not all of the blocks you get are necessarily useful (there are a number of public domain blocks that are just line segments and not arcs or PLine rectangles; some have extraneous atttributes, too).  So, having the blocks is not always the end of it.
    You will likely want to pre-organize some folder/directory structure to store the blocks.  Let me recommend starting with a folder called "Drawings" with a "Details" or "Blocks" subfolder within.  Then, in ACAD, add that folder/directory to the Search Path (which is under Preferences).
    The last batch of useful details I acquired as block libraries, I purchased for use in R12--I'm not sure that any are "left" not redrawn at this point.  It's not necessarily a bad exercise to get other's blocks and redraft them, as that's a pretty simple and defined way to get up to speed.
  2. [email protected] | Oct 08, 2007 10:03pm | #2
    Many fixture manufacturers have blocks available for their products.  All the versions of Autcadd I have used came with the most common blocks such as doors, windows, sinks, etc., but you had to elect to install them.     I can't remember if 2000 had the  "Design Center" or not.
