ADDING A SECOND STORY
| Posted in General Discussion on June 30, 2000 03:53am
Am planning to add a second story to my early 1900’s CRAFTSMAN SYLE HOUSE. My contractor advises using steel or wooden posts/columns at certain intervals throughout the existing structure to support the addition. Does anybody out there have any thoughts as to which method is better? By what methods would the steel beams tie into the existing wood structure/frame? Also,should I go with conventional lumber or I-JOISTS in framing the floor for the second story?
  1. Guest_ | Jun 29, 2000 04:45pm | #1
    Al,
    This is no place for questions like this, to be frank. You have a major construction project, with serious structural issues. You need to have this engineered by someone on site. Your information is WAY too vague for an appropriate response here.
    I'm not going to waste time telling you all the details you would need to provide for this recommendation, in addition to pictures/drawings/sizes, etc.
    Do your homework first, I'm sure you'll get some help then.
    Remember: You can get experts to look at your project. On the internet, who knows?
    MD
  2. Terry_Banbury | Jun 29, 2000 05:25pm | #2
    Mad Dog is right on the money. I would add that you need someone with design sensibilities to protect your investment in your craftsman style home. Although, with such a major addition, that may not be possible.
    TB
  3. Guest_ | Jun 29, 2000 06:30pm | #3
    If you've found a contractor you can rely on. Take his or her word. If you don't trust this guy...maybe you need to find another.
    1. Guest_ | Jun 30, 2000 03:53am | #5
      *And that isn't the half of it. Best of luck.
  4. AL_HERRERA | Jun 30, 2000 03:53am | #4
    Am planning to add a second story to my early 1900's CRAFTSMAN SYLE HOUSE. My contractor advises using steel or wooden posts/columns at certain intervals throughout the existing structure to support the addition. Does anybody out there have any thoughts as to which method is better? By what methods would the steel beams tie into the existing wood structure/frame? Also,should I go with conventional lumber or I-JOISTS in framing the floor for the second story?
  • Townhouse Transformation
  • Mortar for Old Masonry
  • Grout-Free Shower Panels
