adding extra rad cores?
timestamps | Posted in Energy, Heating & Insulation on October 9, 2007 02:17am
Hi everyone
I have a few extra baseboard rad cores left over (opted for in-floor instead) and was wondering if i doubled up on some of my existing baseboard radiation zones, could i expect to get lower return temps on those zones? The cores are “slant fins” 3/4 cooper with aluminum fins. My new boiler is a condensing type and from what i’m told, the lower the temps you run in the system, the better. I guess in a sense, i would be attempting a make shift high output rad to lower my return water temps. One other thing, can you “Over BTU” a zone when using a condensing boiler? Thanks to all!
Edited 10/9/2007 7:54 am ET by timestamps
  1. rich1 | Oct 10, 2007 07:03am | #1
    What you want to do works.  Just make sure that all the extra fintube is on the same zone.    Doubling in one area and not another if they are on the same zone will lead to major complaints.
Podcast Episode 695: Saving Bricks, Cut-and-Cobble Insulation, and Waterproofing Foundations
Listeners write in about paint strippers, bricks, and FHB Podcast volume and ask questions about insulating under membrane roofs and whether waterproofing prevents concrete foundations from drying.
  • Why the FHB Summit Is an Industry Event You Don't Want to Miss
