Adding radiant heat to steam system
| Posted in Energy, Heating & Insulation on March 25, 2003 08:12am
I have a 100 year old house with a 3 year old steam boiler feeding cast iron radiators in a one-pipe system.  My hot water is heated by the boiler and stored in a 40 gallon Thermo tank.  I am about to put a 2 story, 1000 sf addition (plus basement) and would really like to install radiant heat in the floors of the new addition and basement.  Can I use my existing boiler/water heater as the heat source for my radiant heat, or do I need a secondary heating unit?
  1. wallyo | Mar 25, 2003 09:21pm | #1
    As far as I know you cannot feed the radinant floor with steam. You could perhaps use the steam to feed a second Hot water heater then put that in a closed loop to feed the Floor system if the boiler has the capicity.
    One house I did has force air upstairs, the owners dug a basement out put in radinant heat in the slab. The source of hot water is a regular Hot water heater, expanison tank, electric valve and a circulation pump. I don't think it is the best but it was the cheapest and the simplest and it works for them. If it were me I wonder if a instantous hot water heater (BOSH) could be used it is only on when there is a call for hot water.
    1. dudewith | Mar 25, 2003 09:38pm | #2
      Thanks wally,
      I was thinking that I probably needed at least another hot water heater and pump along with the necessary control valves; otherwise I can't figure out how the potable water and radiant heating water would remain separated.
      1. wallyo | Mar 25, 2003 10:34pm | #3
        Yeah.  The house I r refered to has two water heaters one for domestic the other for the slab loop.
  2. BungalowJeff | Mar 27, 2003 08:12am | #4
    Try here:
    http://64.226.150.132/hydronic/steam/steam1.htm#Steam%20Related%20Tech%20Talk%20Articles
    ...that's not a mistake, it's rustic
  3. Wet_Head | Mar 27, 2003 08:31am | #5
    nah... just run some open steam pipes into the floor...
    just kidding.
    no need to buy a separate unit.  you need a steam to water heat exchanger.  that's all.  of course you need the temp controls etc after that but...
