Why do you want a standing seam roof under the shingles?
Wouldn’t it look better to match your other roofing?
Maybe a little more detail or a picture would help. At
least give us the basic configuration, roof slopes, and your
geographic location?
Wouldn't it look better to match your other roofing?
Mad Dog,
Thanks for your note. I have attached a Word doc drawing of the present and proposed addition. The house has a 5-12 composition roof and the addition will have about a 1-12 pitch, hence the idea to use the metal roof. I want to raise the rafters in order to be able to use standard doors to the exterior. I thought about doing the California roof, but there is a fireplace in the corner of the L which would complicate the flashing. However, I do want the job to turn out well, so I will consider anything! Our choices are limited in shape, because as planned, the addition wraps around a swimming pool. My location is Dallas, TX. Hope to hear from you soon and a prayer for the Cowboys won't hurt either!
I am preparing to add a symmetric leg along the other wall on to an existing 11x22 enclosed patio addition that has 2x8 rough cedar rafters on 2x8 headers attached to 4x4s on 4 ft centers. The roof is presently fiberglass. The rafters tie-in to the house by being notched and fitted under the overhang and over the header. I am thinking about removing the fascia and raising the rafters to attach to the house roof trusses, thus giving me about 6-8" more headroom and allowing me to raise the outside wall to a better height. I plan to use 1/2" sheathing and 3/4" rigid insulation, topped by a standing seam metal roof tied in under the shingles. Does this sound workable? If not, any suggestions. Thanks for any help available!
