A friend has an undermount sink in the bathroom that is becoming detached from the countertop. It apparently has no clips or other mechanical fasteners to hold it up. Only the caulk. The caulk is failing and the weight is being transfered to the waste pipe.
Is that normal? Are those things usually installed with only caulk to hold them up? Should there be some clips?
yep yep yep
dave
Wow. That's a concise reply. :^)But I think I get the message. Thanks.
