advice needed paperless drywall
ZEEYA | Posted in General Discussion on April 18, 2007 01:44am
I have an HO who wants me to use paperless drywall her brother told her it’s the only way to go to prevent mold & mildew.  I’ve not used it on any remodels this is for a small bathroom no tile work involved any tips would be helpful.
Thanks in advance
Zeeya
  1. vintage1 | Apr 18, 2007 02:02am | #1
    Z-
    The stuff is faced with f/g and it can be itchy, like working with insulation.  Some have said it is heavier per sheet, but I haven't done enough with it to say one way or another.
    While it may be less likely to support mold growth in a moist enviornment, I wouldn't substitute it in places where CBU or a membrane under tile are warranted.
  2. Zano | Apr 18, 2007 02:16am | #2
    It's exterior gypsum sheating in a white color. Wear a good respirator when installing for the fiberglass will fly all over. The entire board has to be skim coated as the material is not perfectly flat as regular gypsum. The screws puncture the material and do not hold it well.
    Suggest using National Gypsum XP Drywall..purple colored which is anti mold and has paper on it.
  3. FastEddie | Apr 18, 2007 02:17am | #3
    I think you will find that it is only good as long as it stays in full sheets.  Once you cut it, the gypsum core is exposed and that will support mold, so all cut edges have to be sealed.
    If it is only being used for wall inthe dry areas of the room, it would be ok.  Green board would be a good choice too.  But neither is a good choice for a wet area like a tub or shower enclosure.
  4. rpait | Apr 18, 2007 03:28am | #4
    what I would use is blue board or green board, wonderboard or creteboard. or anyother board used for kitchens and baths. forget about the paperless drywall. We all know that mold and mildew is a product of moisture + warmth + darkness. the key to preventing mold and mildew is seal properly the surface and keep wiped dry.
PVC for a Rot-Proof Fence
Built with rot-proof material with traditional tools and techniques, this classic border is engineered to never sag.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
