I am looking for someone to advise me on the practical aspects of taking down a 1790’s Dutch barn. I haven’t the funds to hire one of the professional groups to do it, but would like to save the beams. See pic
I think your pic is awol.
Maybe it's the 'after' pic.
hopefully pic is found
Edited 10/28/2008 3:28 pm ET by mcguire
I don't think he could have an after pic yet. He has to pull it down first but you could be right, temporal paradoxes always confuse me.
Maybe junkhound had already showed up.
He has a unique approach to barn dismantlemanship.
I've done several similars in past years - -
here's a pict of the specialty tools I use -
Like all Picts ... no where to be seen any more. http://en.wikipedia.org/wiki/Picts
ya - it was a poor joke - anyway - mcguire! - it comes down in reverse order of going up - start with the roof, (or pull the siding, it doesn't matter) remove remaining roofing, then sheathing, then rafters - collapse the purlins, usually you'll then lay the long sides down, then the bents - be careful, plan so you aren't working in debris, and be careful, clean stuff up as you go, and be careful - - a 2.5 pound hand sledge is good, get a large bolt to use as a drift to drive the pins out - try posting your pictures again - D"there's enough for everyone"
Just unpeg it and carefully lift off the pieces, or after unpegging it and taking out all fastener-connectors & lateral supports, cable the two corner end post to a come-along and have at it. They just fold down to the ground like a pile of sticks. Seen it done and it was the coolest.
Be careful when unpegging it though.
Art,
How is the easy way you recommend to remove those sheathing boards again?
It is, of course, important to maintain the stability of the structure you are working on untill you are actually ready to topple it over.
I just saw a piece on Renovation Nation (or sumpthing to the effect, chn 194 on Dish) with a much older Steve Thomas going over such a dissemlby with a guy that does this in the NorthEast.
They had a whole lot of scaffolding.
And telehandlers.
And labor.
invest in a couple of books -
this is a great one: http://www.abebooks.com/servlet/SearchResults?an=arthur&sts=t&tn=the+barn&x=0&y=0
Eric Sloane's work is good too - this is a good one: http://www.abebooks.com/servlet/BookDetailsPL?bi=1189990786&searchurl=an%3Dsloane%26sts%3Dt%26tn%3Damerica%26x%3D0%26y%3D0
