I’m doing some light-weight work in my den- adding some built in cabinets, etc. The existing ceiling meets the new drywall. Instead of trying to match a 50-year old ceiling, I decided to re-skim the entire ceiling. Should be straightforward, right?
When I did the new sheetrock, no problem. Working on the existing ceiling, though- mmm…. As the joint compound hardens, tiny air bubbles formed in the plaster. I’m not oing for a glass-smooth ceiling, so in some respects I’m inclined to just sand off the bubbles and let them add just a bit more chaacter to the ceiling, but I’d like to know what’s happening and why. Any advice?
BTW, the old ceiling texture is pretty minimal- looks like a slightly wrinkled sheet.
Thanks.
“Honey, will you please make some sawdust and track it across the carpet?”
“Yes, dear…”
mix too dry...
too hard of knief pressure...
dust on the old SR....
add a little liquid dish soap to yur compound..
WOW!!! What a Ride!
why the liquid dish soap?
improves cohesion.. (did I use the right word?) makes it trowel more gooder.........Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming<!----><!----><!---->
Joint compound on painted surface will cause bubbles to appear. They usually dry to a small pinhole. 2nd coat should fill it in.
Quittin' Time
