Hi,
How do keep the air inside a seasonal cottage fresh when it’s sealed up quite a bit?
Is there an air exchanger you could recommend that’s available in Ontario?
Thanks!
Hi,
Thanks!
What's your budget?
<$100
https://na.panasonic.com/us/home-and-building-solutions/ventilation-indoor-air-quality/ventilation-fans/whispervaluer-dctm-pick
Size as needed. Let it run 24/7 at low speed.
More Options, more money.
Frankie
Thanks Frankie!
Would we just leave this running when we aren't there?
Would this be installed in the bathroom?
Let it run continuous 24/7. It uses very little energy.
Install where the most air exchange is needed (largest room) but it might then draw airflow from the bathroom after use. Maybe install a second one in bathroom to use while there.
Frankie
It'll exhaust bathroom odors while you
“[Deleted]”
Why not consider a passive option? Install a couple vents that vary in intake height.
