Does anyone know of a brand of air fitting that does not leak?
If not the normal, what about a differant type of air fitting?
I thought about hooking the hose straight to the air guns, but then I would have to roll the guns and the hose up at the same time. Not the most efficient use of time. But I get so sick of hearing air hissing all the time.
Stop buying the cheapest ones you can find.
The person you offend today, may have been your best friend tomorrow
If I was set on buying the cheapest, would I be asking around for the best, Hmmm?
So, two votes for milton. Do you have a suggestion or just smart a$$ comments?
Where are the best place to get good fittings? Obviously not at the big boxes.
auto parts store..just get the right KIND of fitting, there are 3 IIRC.
I'll just do it>
Just smart a$$ comments.:)
A lot of the time the male nipples that come with the tool are of poor quality.
Replace them with Milton.
Don't use the brass male nips.
the steel ball bearings in the female couplers will deform the softer brass, causing leekage.
Mr T
I can't afford to be affordable anymore
Another vote for Milton.
Jon Blakemore
