FHB Logo Facebook LinkedIn Email Pinterest Twitter Instagram Tiktok YouTube Plus Icon Close Icon Navigation Search Icon Navigation Search Icon Arrow Down Icon Video Guide Icon Article Guide Icon Modal Close Icon Guide Search Icon Skip to content
Air intake for A/C?
| Posted in General Discussion on July 16, 2000 02:39am
Is there a type of central A/C that uses an “air intake” Several news stories about some CO deaths in NY a few months ago have mentioned this: for example, this snippet from the Baltimore Sun:
QUOTE
Dr. Andrei Kranz disconnected the carbon monoxide
detector in his Long Island, N.Y., home last summer because the
device kept going off for no apparent reason and waking the family.
In May, Kranz came home to find his parents, his 3-year-old
daughter, the nanny and two houseguests dead in their beds, all
victims of carbon monoxide poisoning.
Police investigators found that someone had turned on the air
conditioner without shutting off the furnace. The air conditioner’s
intake filter was clogged with leaves, so the cooling system
drew in furnace fumes instead.
END QUOTE
I’ve been puzzling over this for awhile; never seen such a beast.
Bob
  1. Lorne_Lambert | Jul 15, 2000 01:44am | #1
    In some cases where the furnace or other gas appliance are located in a small room, where gas fired appliances per 1000 bus of input do not have 50 q. in. of area in the room,there must be combustion air from outside brought in. Still this may not solve the problem. Return air must be sealed to prevent a room from going negative. There are fresh air devices that connect to the return air with a barometric damper in them to control air flow. Then cut a supply register in the plenum to positively pressurize the room. This so be done by a qualified a/I etch, but there are so few.
    1. Bob_Walker | Jul 15, 2000 01:04pm | #2
      *Lorne,That part I'm familiar with, but its the "air intake for the A/C" which has me puzzled.Do you suppose they meant that the central air _return_ was blocked, so the A/C air handler started pulling through leaks in the return in the utility room?"This so be done by a qualified a/I etch, but thereare so few."Yesterday I inspected a house that had major flue gas spillage from the water heater bonnet. Probably because there was a 90 degree elbow on the bonnet, about a 10' - 12' horizontal (slightly inclined) run to the chimney. The owners told me that they had had the gas co out a year before because of a gas leak and were told that the "systems were fine" and had had a chimney sweep check the flues and fire places out. They didn't mention any HVAC technicians, but, come on now.Bob
      1. Mongo_ | Jul 16, 2000 04:00am | #3
        *With all due respect to the Doctor's dead family, and with little respect to the Doctor...I just hate reading about these "accidents".Here's an apparently well-educated man who cares enough for his family to install, or at least upkeep, a monitor that is designed to detect a lethal gas that is colorless, odorless, tasteless, etc.The monitor continually goes off...yet it must be a false alarm, since he doesn't see, smell, or taste anything abnormal in the air.Thus, since the alarm designed to detect the lethal, colorless, odorless, and tasteless gas is contantly sounding and he doesn't see, smell, or taste anything, then the alarm must be bad.I sure hope he's a PhD and not an MD. Yeah, yeah, he's grieving...I would be to if played a role in my family's death.Frustratedy, and with nothing constructive to add to this thread, Mongo
        1. Bob_Walker | Jul 16, 2000 02:39pm | #4
          *There has been some question raised as to whether he had disabled the detector; the first reports said he did, the second round of reports mentioned that he disputed statements attributed to him, without specifying exactly what he was disputing.He is a medical MD.There is a great deal of stupidity in the area of CO.The "Chicago" experience is a prime example. Awhile ago, Chicago passed an ordinance requiring CO detectors in homes (maybe just rentals?) The heating season came, and alarms started sounding (thousands.) As I heard it from Jim Davis, the leading expert on CO analysis, the gas and fire companies responded to the alarms, using (i) Monoxor (_Not_ Monoxor II) CO detectors - which have a minimum threshhold of 100ppm, and (ii) Tiff combustible gas detectors which can detect CO down to 2,000 ppm!They decided that the alarms were all (mostly?) false alarms and the city rescinded the ordinace (and gave CO detectors a black eye.)Then, at the urging of the gas industry, among others, UL revised the standards for CO alarms making them far less sensitive to low levels.Although everyone knows CO can kill at high concentrations, its not as widely known that it can cause some pretty serious, long lasting health effects at low levels with chronic exposure.Another example: my local fire dept responds to CO alarms, but has a CO problem in its own building, so it's instruments are completely undependable!Bob
  2. Bob_Walker | Jul 16, 2000 02:39pm | #5
    Is there a type of central A/C that uses an "air intake" Several news stories about some CO deaths in NY a few months ago have mentioned this: for example, this snippet from the Baltimore Sun:
    QUOTE
    conditioner without shutting off the furnace. The air conditioner's
    END QUOTE
    I've been puzzling over this for awhile; never seen such a beast.
    Bob
Fastening Outside Corner Bead
On an outside corner formed by a double layer of drywall, the corner bead can be fastened without nails or screws.
  • Balancing Window Selections for Performance and Budget
  • Issue #320 – Dec. 2023/Jan. 2024
  • Podcast 607: Wood Foundations for Winter Builds, Adding Headroom, and Aeroseal for Leaky Ducts
  • Podcast 607: Members-only Aftershow—Holiday Gifts for Home-Building Enthusiasts
BOOKS, DVDs, & MERCH
Shop the Store
  • Code Check Complete 3rd Edition
    Buy Now
  • 2023 Fine Homebuilding Archive
    Buy Now
  • Pretty Good House
    Buy Now
  • 2024 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 320 - Dec 2023/Jan 2024
    • How to Reuse Salvaged Wood
    • Chainsaw Retrofit and Energy Performance
    • Maximize HVAC Efficiency
  • Issue 319 - November 2023
    • Nearly Net-Zero ADU
    • An Easy Approach to Coffered Ceilings
    • Understanding Types of Roof Vents
  • Issue 318 - October 2023
    • Make Mudsills Square and Level
    • Turn Up the Heat With Induction Cooktops
    • The Fine Homebuilding Interview: Lloyd Alter
  • Issue 317 - Aug/Sept 2023
    • Finishing Drywall With Seamless Results
    • A Flat Roof in a Cold Climate
    • Compact Cordless Shop Vacs
  • Issue 316 - July 2023
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
