I am working on a 1906 house with cedar shingles up and lap siding down. The shingles have been ground bare. The homeowners have asked for an alkyd solid stain. I plan on using an alkyd primer on the eaves and 1st floor siding. Is it ok to shoot the same primer where I will be applying an alkyd stain? Will the primer help or hinder the appearance of the stain- i.e., help by providing a consistent base coat or hurt by inhibiting absorption of stain?
Second question. Is it ok to rinse off the sanding dust and debris before painting, or do I risk damaging the bare and very dry shingles?
Thanks in advance for sharing your actual experience.
-Mike
ihbase-
I can't answer the 2nd question about the dust except to say you need to give the siding time to dry before "painting", but I've had fair luck with solid oil stain over oil prime. The stain, at that point is closer to paint than stain.
Don K.
EJG Homes Renovations - New Construction - Rentals
Don and nikkiwood, Thanks a lot for taking the time to reply. I appreciate your advice.-Mike
I never use a stain of this sort over an alkyd paint primer.
however, I would check with the tech services people for the brand you are using.
It certainly won't hurt to rinse off the shingles with a garden hose, but you need to allow enough time for thorough drying, assuming you are using alkyd products.
I trust you know that a pressure washer can do a lot of damage to cedar.
"It is what we learn after we think we know it all, that counts."
John Wooden 1910-
On all my cedar fences I made i used Cabots Problem solver oil primer and then used their solid color stain. works great.
On my cedar shingle house...I did hose all the areas to be painted with 1:4 bleach and water in a power washer a week before i painted. I did however satnd wayyyyyyy back and was really careful to use the right nozzle so as not to damage any shingles. I then checked each area prior to painting with a moisture meter.
On the house I used a BM oil primer and latex top coats.
I had great success.
Creation arises, is sustained for awhile, and then things change. That’s the dance.
Thanks Andy.-Mike
