Hi!
Next to my house, where I am installing a window well, I have dug a 6″ hole down about 103″, which I believe has gotten me just above the drain tile. I can hear a hollow sound when I bang on the bottom of the hole with the post hole digger. Now, am I going to have to break through and into a pvc pipe? Or am I just going to dig into a layer of stone? I plan to use a 4″ pipe in the hole, up to the level of the window well. Should I use any special type of pipe?
Thanks for you help.
P.S. I am using a manual post hole digger.
Greetings cicerored,
This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
Perhaps it will catch someone's attention that can help you with advice.
Cheers
94969.19 In the beginning there was Breaktime...
94969.1 Photo Gallery Table of Contents
Not a good idea to break what is there!
That must be a long pair of handles on your post hole digger!
I was thinking the same. Clearly not clam shell type either.BruceT
Edited 5/23/2009 11:53 am by brucet9
