Help, for my new house I’m considering heart pine flooring that has been milled from reclaimed antique timbers. Depending on what I chose,the price is somewhat more than new hardwood flooring.
I need to know what to expect with regard to the installation and finishing cost/issues. Is it more difficult to install and finish, do most flooring contractors charge a preminum to install and finish, some of the suppliers say you can DIY — has anyone tried to DIY. What is the proper procedure to install and finish it?
When I work with old heart pine in my workshop it’s hard on cutting tools and gums sand paper badly. I would think the floors would be hard to sand, what’s your experience?
Make sure your flooring is milled in a machine that mills all 4 sides at once. This will keep the tollorance between individual strips tight, within a few thousandths. This will result in a floor that needs little sanding to even the floor. Just a light sanding to produce a quality finish.
Heart Pine does clog sandpaper worse than oak, cherry, walnut etc. But it's a soft wood compared to these species. As for installation costs, it shouldn't cost any than oak, unless you are going for wide planks which may require a little more work, i.e. drilling, screews and plugs. Finishing costs for me run a little higher but not enough to fret about.
*Ditto the above, with another caviat: Your heartpine floor will dent easier than hardwoods. Use care with furnishings, and foot traffic.
Thanks guys of your input. Lee, Dave, thanks for your e-mail. Each of you had info that was helpful.
Thanks Again for taking the time!
Bill
Help, for my new house I'm considering heart pine flooring that has been milled from reclaimed antique timbers. Depending on what I chose,the price is somewhat more than new hardwood flooring.
I need to know what to expect with regard to the installation and finishing cost/issues. Is it more difficult to install and finish, do most flooring contractors charge a preminum to install and finish, some of the suppliers say you can DIY -- has anyone tried to DIY. What is the proper procedure to install and finish it?
When I work with old heart pine in my workshop it's hard on cutting tools and gums sand paper badly. I would think the floors would be hard to sand, what's your experience?
