Tina:
I’ve used it, it’s basically a wiping varnish. As w/ most products of this nature, you can’t rigidly follow the can directions, it’s a function of temperature, and porosity of wood. I leave it on til it just starts to polymerize (turn gummy)…then apply some good elbow grease to force it into pores and wipe
b dry.
Use two cloths (helps with fingerprints)of progressively dryer cotton, making your final wiping/drying strokes w/ the grain.
b Soak rags and dispose of.
Don’t get too far ahead of yourself…you let to much finish start to set and you’ve got a mess on your hands. Also check the wood for “bleedback” after you’ve wiped dry…some woods does, some doesn’t. I achieved good results on some kitchen cabinets in NC..but haven’t run across it here in so CA. But its good stuff.
Get a closer look at the building process for this durable, flush, lightweight door.
Tina:
I've used it, it's basically a wiping varnish. As w/ most products of this nature, you can't rigidly follow the can directions, it's a function of temperature, and porosity of wood. I leave it on til it just starts to polymerize (turn gummy)...then apply some good elbow grease to force it into pores and wipe
b dry.
Don't get too far ahead of yourself...you let to much finish start to set and you've got a mess on your hands. Also check the wood for "bleedback" after you've wiped dry...some woods does, some doesn't. I achieved good results on some kitchen cabinets in NC..but haven't run across it here in so CA. But its good stuff.
No, it's not for massages (or I'd have posted this in the Tavern). It's a wood finish. Thinking of using it on windows (inside). Similar, I think, to old fashioned tung oil, which I've used successfully on Shaker rocker. Am waiting for brochure and samples from Mfg.
