I’m going to be building an exterior stair for an architect friend who likes to see how complicated he can make things. It’ll be a second means of egress for his 3-decker. He wants to use only two posts, with the stair wrapping around them, each run is 1/2 a flight, with landings at each end. Hard to describe, but picture a helix. Each landing will have a step in the middle, to fit everything in. One landing butts against the house, the other hangs out in mid-air. The biggest problem I can see is a see-saw effect when you stand on the outside corner of the landings. I suggested steel brackets, but if possible he’d rather do it all in wood. Anyone have suggestions?
MM
I'm going to be building an exterior stair for an architect friend who likes to see how complicated he can make things. It'll be a second means of egress for his 3-decker. He wants to use only two posts, with the stair wrapping around them, each run is 1/2 a flight, with landings at each end. Hard to describe, but picture a helix. Each landing will have a step in the middle, to fit everything in. One landing butts against the house, the other hangs out in mid-air. The biggest problem I can see is a see-saw effect when you stand on the outside corner of the landings. I suggested steel brackets, but if possible he'd rather do it all in wood. Anyone have suggestions?
MM
