All you D-Mix nuts out there: Finally boned up the guts to do one of the side walls in my stairwell. Whomped up about 60% of a 5 gal bucket of JC; half gal of PVA & a FULL DD cup of PoP. Worked like a charm. Getting better w/ the rubber squeegee type thingy. Reducing the amount of sanding needed. Can see nearly zero sanding w/i my grasp.
I’ll reiterate – never learn a new process on a stairwell. At least the stairwell is 54 inches wide.
Don
Whats a "D-Mix" ????
(g)
May you bite your tongue while it is in your cheek!!!DonThe GlassMasterworks - If it scratches, I etch it!
Jeez, Don. I adopt a new religion and you call me a "nut." Tolerance, please.
-SB
Thanks for the report Don!
What kind/size coffee did you drink?
Cream and sugar or black?
blue
Just because you can, doesn't mean you should!
Warning! Be cautious when taking any framing advice from me. There are some in here who think I'm a hackmeister...they might be right! Of course, they might be wrong too!
Blue, you old Devil. You didn't ask about caffine content!DonThe GlassMasterworks - If it scratches, I etch it!
Don! I forgot about that!
I'll bet that's the source of all the problems!
Frigging Decaf!
blueJust because you can, doesn't mean you should!
Yeh! The caffine makes it set up faster - but probably w/ a wavy surface.DonThe GlassMasterworks - If it scratches, I etch it!
