Just thought I would post a few pictures of my attic. I spent a lot of time sealing the air leaks at the ceiling penetrations. Attempted to seal the return air ducts. Insulated the knee walls with foam. Then had insulation blown in on top of the fiberglass. I should have done a few in progress pictures which would have made things a little clearer, but I think you will get the idea.
Insulation complete.
I assume you didn't get any insulation around any lights that are not rated for such.Is it allowable to have foam exposed in the attic?I don't see any pics of foam sprayed into the holes the electrical lines are going through.Other than that, it really does look great. I bet your toastier already.It is still cold in North Texas, right?
Rich Beckman
This signature line intentionally left blank
