Need your opinion about attic ventilation.
I have a small Cape Cod home which I have removed the siding, tyveked it and installed all new construction aluminum clad windows. I will be replacing the siding with cement board. The roof was recently done with ridge and soffit vents. The Cape has two finished rooms upstairs with a small dormer over the half bath. Since the upstairs bedrooms were extremely hot in the summer months. (A New Hampshire located home), I installed a temperature and a humidly controlled automatic fan in the small dormer above the half bath.
The problem. After installing the fan, I later found out that I created a problem because of the ridge vents. I found out that you can not have two types of venting together, as they will “short circuit”. ie, the fan will pull outside air through the ridge vent above the fan, as it is only a couple of feet away from the top of the fan.
My initial thoughts were , that I either have to remove the new fan, or remove the ridge vents.
My new thoughts are as follows, which I would like your opinion on.
The Cape has knee walls, and is insulated with fiberglass insulation from the soffit to the top of the knee wall. (I added foam channels between the insulation and the roof deck). I am thinking of continuing the foam channels up to the ridge vent. This will give me a clear shot from the soffit to the ridge. Add insulation all the way up to the ridge vent, then seal the attic with 1/4″ plywood, both above, and below where the knee wall meets the roof joists. This will allow me to have ventilation from the soffit to the ridge with no leakage into the attic. Keeping the roof deck cold in the winter months and allowing me to use the automatic gable fan in the half bath dormer, which will also be sealed the same way as well.
What do you think. Am I all wet or is this acceptable.
Thank You, Ray
Edited 6/29/2006 10:40 am ET by rayem
Well, by insulating under the air channels, you are raising the "conditioned space" to include your attic... this is a good thing. At that point, you should not need to use the fan anymore. I would suggest using horizontal nailers to give a thermal break from the rafters, then using drywall on the underside instead of plywood.
Also a CRX fanatic!
Don't run the fan?
There is no cure for stupid. R. White.
Hi. I have almost the same idea for my Cape Cod (because I have terrible heat gain up stairs that my newly installed central air doesn't handle very well) but was wondering how are you going to slip insulation up to the ridge vent in that small opening above the kneewall where it meets the roof rafters? Wouldn't the roofing nails that protrude thru the roof deck impede pushing the insulation up there?
Also,
I've read in this forum that you should install drywall instead of that 1/4" plywood because fire code says so.
